    64' Econo Axle Fit a 67'?
    Number of posts : 726
    Registration date : 2012-09-26
    64' Econo Axle Fit a 67'? Empty 64' Econo Axle Fit a 67'?
    Post by NoBiggie Fri Mar 22, 2013 7:49 pm
    Will a 1964 Econo Axle fit a 1967?
    Number of posts : 1747
    64' Econo Axle Fit a 67'? Empty Re: 64' Econo Axle Fit a 67'?
    Post by econopoor Sat Mar 23, 2013 8:20 am
    All the first gen Econoline axles interchange. The 61 - 63 1/2 had different king pins but will still work. I assume you are talking front?
    Duane in Tennessee.
    Number of posts : 2011
    Post by Barnabas Sat Mar 23, 2013 9:25 am
    Rear axles are all interchangable as well from 1961 to 1967. Drive shaft may have to be also swapped.
    Post by NoBiggie Sat Mar 23, 2013 9:42 am
    Thanks! Yes I was talking front, but it's good to know about the rear too.
    Old Skool
    Number of posts : 1306
    Post by Old Skool Thu Mar 28, 2013 9:38 pm
    All the front axles are identical, the difference is in the spindles not the axle. 64 and up greased from end caps, the early ones greased in the center of each bushing through a zirc fitting drilled in the spindle itself. There are also two different height steering arms for bump steer geometry.
    old skool
      Current date/time is Thu May 16, 2024 9:52 pm
