Jfox... if you had found water leaks after installing the seals, what do you do to fix them?
+6
mattimuss
JariV
Dawgboy
Schoessow
10 posters
front windshield replacement rubber seal.
jfox- Number of posts : 111
Luckily it wasn't an issue for me. Like anything the devil is in the details. I thoroughly cleaned the channel on the van with a wire brush, then examined the entire surface for any burs and addressed those with a file and primer. I suppose if i had a leak i would repeat the process.westcoastvanner wrote:Jfox... if you had found water leaks after installing the seals, what do you do to fix them?
mattimuss- Number of posts : 205
Hey jfox,
I am very sorry I missed helping you on this. Family and work have both been chaotic lately. I would have learned a lot for sure.
Matt
Matt
Right there with ya. If your inclined to save a few bucks i would give it a shot. I'll help/or watch with a beer in my hand.mattimuss wrote:Hey jfox,
Matt
Anybody use a pro to do this? I tried to do it on my 69 a108 and gave up.
Want to make sure I don't need a special vintage guy.
I did, it cost me $90.00 but it looks great, well worth having the pros do it!
westcoastvanner wrote:I did, it cost me $90.00 but it looks great, well worth having the pros do it!
Did you just look up a standard glass guy?
I am gonna pull the trigger just need the right direction.
Yes... a standard glass guy? It took two guys about an hour, they did a great job.
Yeah I meant not a vintage specialist. It's pretty simple, but just checking.
i had a pro do mine, it took him alone a half hour, but he new what he was doing, he said he has done a lot of big rigs ''semi trucks'', i gues they have the same tipe seals, just find a pro thats done some trucks
