    Powdercoating Potmetal???
    Das Boot
    Das Boot
    Number of posts : 76
    Powdercoating Potmetal??? Empty Powdercoating Potmetal???
    Post by Das Boot Sun Mar 17, 2013 3:14 pm
    So I've been wanting to try out powdering coating and picked up a gun at HB. I need to find a good smaller part to try and decided to do my rear view mirror. I've about got the 10 coats of paint off from it with my air eraser and decided to scour the internet for tips on powder coating potmetal, but I can't get a definite answer on whether to do it or not due to out gassing. The metal is cleaning up really good and I don't see any pits in it, has anyone else done this or had it done with success or should I just paint it?
    Das Boot
    Das Boot
    Powdercoating Potmetal??? Empty Re: Powdercoating Potmetal???
    Post by Das Boot Sat Mar 30, 2013 11:56 am
    I just decided to try it because I couldn't find a good answer. For the most part it turned out good, but if I had to do it all over again, I would paint it. The arm is thicker than the rest and took longer to get to temperature and looks a little orange peeled. One thing is, it looks better than it did.
    Powdercoating Potmetal??? Mirror10
    Powdercoating Potmetal??? Mirror11
    Powdercoating Potmetal??? Mirror12
    Post by G-Man Sat Mar 30, 2013 12:16 pm
    Sorry I didn't see your post ealier, I has powder coat a cast waterneck with Hi temp powder coating
    Das Boot
    Das Boot
    Post by Das Boot Sat Mar 30, 2013 3:03 pm
    How is it holding up to the temperature? I'm planning on a partial rebuild over the summer and had thought about doing the valve cover and fan.
    Post by G-Man Sat Mar 30, 2013 9:05 pm
    seems to be holding up good
    econoaddict
    econoaddict
    Number of posts : 42
    Registration date : 2012-06-15
    Post by econoaddict Sun Mar 31, 2013 1:23 pm
    One trick I found is to prebake the parts and then do a wipe down cleaning, then prewarm before coating.
    Basically cook out all the garbage that has soaked in over the years.
      Similar topics
      Current date/time is Thu May 16, 2024 8:41 pm
