    frame measurement..help
    frame measurement..help Empty frame measurement..help
    Post by Guest Sat Jan 24, 2009 12:36 pm
    I was wondering if anyone has... or can measure the inside frame rails...for lack of better terms.....I am trying to determine the maximum width radiator i can place between the rails...and I havent got my truck here to do so.......thanx
    Number of posts : 1388
    frame measurement..help Empty Re: frame measurement..help
    Post by wideload Sat Jan 24, 2009 7:13 pm
    I can get that measurement for you tomorrow but I think the frame rails are wider than the doghouse.
    Post by Guest Sat Jan 24, 2009 8:50 pm
    ok that is a help for me..the rad i am looking at is about 26 inches wide...it came with the motor i have for my 66 chevy....and it is a four core with huge tanks.....just wasnt sure about the width......i know i am going to have to widen my doghouse anyways...if not go for a dodge one for that matter...but if u can measure for me thanx alot....then i can scoop this rad before someone else does......
    Post by donivan65 Sat Jan 24, 2009 8:58 pm
    The 2nd Gens run this 4 row sitting down low inside those bump outs under the seats in their doghouse,,,,
    frame measurement..help 4_row110
    frame measurement..help 4_row111
    Post by wideload Sun Jan 25, 2009 11:11 am
    Hemi the frame measures 32" inside just in front of the radiator. Another thing to consider is that all the linkage for the trans and throttle run down the inside of the frame on the drivers side and there is a brake line on the inside of the frame on the pass side. Hope this helps.
    Post by Guest Sun Jan 25, 2009 2:47 pm
    yes it helps me alot...thanks for all your trouble......love your truck sits nice too!!!....also thanks donivan for your input......
      Current date/time is Fri May 17, 2024 12:33 am
