Staypuff68
mikeysly
    radiator upgrade
    mikeysly
    mikeysly
    Number of posts : 284
    radiator upgrade Empty radiator upgrade
    Post by mikeysly Thu Feb 21, 2013 11:00 am
    my original radiator core is shot. guy says tanks are fine but he wants 400ish to give me a new core! i think that's crazy high! (haha) is there an easy new bolt-up replacement aftermarket aluminum radiator available yet? i'm running a straight six 250 with an original downflow(?) radiator and i want my motor super cool and my heat super hot. any suggestions?
    Staypuff68
    Registration date : 2011-03-02
    radiator upgrade Empty Re: radiator upgrade
    Post by Staypuff68 Thu Feb 21, 2013 6:43 pm
    I got one for my 2nd gen V8 out of a 94(ish) dodge van. The width was fine but it is a little taller (say 5-6 inches) so you will need to make extensions. The hoses fit just fine.[img][/img][img][/img]
    Post by Nightmoves Thu Feb 21, 2013 10:11 pm
    Mikey , to best of knowledge , there's no off the shelf, GM replacement, exact measurement radiator out there.Some are close, but modified to fit.
    A few folks have an aluminum one made and close to price you mentioned.
    Not enough demand like a Camaro or Chevelle .
    diamond dave
    diamond dave
    Number of posts : 565
    Post by diamond dave Fri Feb 22, 2013 6:07 am
    i build a ton of custom cars, trucks and vans. and i'm also really close to summit racing. i always measure up the radiator, and find a universal aluminum one in their catalog that is reasonably close in size to use. they are usually under $150 and work awesome. never had a problem out of one. the only thing you have to do is run an external tranny cooler
    slowleak
    slowleak
    Number of posts : 9
    Registration date : 2011-08-23
    Post by slowleak Tue Apr 02, 2013 1:23 pm
    Hey man - '67 Mercury Cougar radiator fits REALLY nicely, you do have to drill some holes in two strips of aluminum to 'bridge' the distance. The Cougar rad is just a tad narrower. simple upgrade, very cheap on ebay, $180 or so, built in tranny cooler. just pay attention to hose routing, you can flip the thermostat housing but you want to have the bottom one on the correct side. I'm also running a 250, the rad cools nicely in super hot summers.
    Number of posts : 394
    Post by dan nachel Tue Apr 02, 2013 4:23 pm
    Are you using the 1,2,or3 row? (core tubes)
    slowleak
    slowleak
    Number of posts : 9
    Post by slowleak Tue Apr 02, 2013 4:29 pm
    2, but 3 would fit just fine
    Post by Twinpilot001 Tue Apr 02, 2013 5:12 pm
    just bought a diff radiator from these guys - look @ this -if wonthttp://www.ebay.com/itm/180767417429?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649 work 4 the econos?? likely they have something!!
      Current date/time is Sun May 19, 2024 9:26 pm
