    Under windshield gasket. UGLY !
    gkpost
    gkpost
    Number of posts : 224
    Under windshield gasket. UGLY ! Empty Under windshield gasket. UGLY !
    Post by gkpost Mon Jan 21, 2013 6:53 am
    I wasn't expecting anything else but maybe more rot. Now I'm sure most of you have been threw this before, A big rot mess under the windshield gasket. so whats the best way to fix this? A friend told me to use ALL METAL and get on with my life. Dosen't sound like the right way to fix rot but I'm not a body guy.Thanks for any help
    ~ GK.
    Under windshield gasket. UGLY ! Empty Re: Under windshield gasket. UGLY !
    Post by Digz Mon Jan 21, 2013 7:06 am
    Depends on how bad it is? Any pics? Missing alot probably weld in patches. If your looking at pinholes and such and you don't want to open it up, clean it up hit with some spray can rust converter and maybe use that stuff to fill them in and put some primer and paint on it to seal it. Big thing is "trying" to stop or get rid of what rust is there and getting things sealed up to keep water from hurting it any further. No guarantees but would by some time. Dura glass would also work as a filler if you can keep the water from getting back in, again prime and paint to seal it.
    JM2C for a quik n easy.
    gkpost
    gkpost
    Post by gkpost Mon Jan 21, 2013 11:24 am
    I think I got this!
    Under windshield gasket. UGLY ! P1020011
    Bear
    Bear
    Number of posts : 849
    Post by Bear Mon Jan 21, 2013 12:56 pm
    seen worse not too bad
    Post by Digz Mon Jan 21, 2013 1:40 pm
    Ya , could be worse. I think it's a candidate for some patching tho. That's quite a long stretch and I suppose could separate on you. See how the Body work gurus chime in.
    Post by millwright71 Mon Jan 21, 2013 2:11 pm
    It definitely needs patching, how much can be determined by poking all the way along there with an ice pick, or scratch awl. Anywhere it goes through, needs new metal welded in. That is the test I always use anyway.
    ChevyVanMan1
    Number of posts : 425
    Post by ChevyVanMan1 Mon Jan 21, 2013 2:47 pm
    After you get it all patched don't forget to drill about 3 holes and seal them with paint right in the bottom of the crevice. This will give water a chance to seep out. You might notice a drip stain on the inside but it won't be much water--just enough to keep the new metal from rusting out like the old. Good luck.
      Current date/time is Sun Apr 28, 2024 7:10 am
