    radiator retro fit
    radiator retro fit Empty radiator retro fit
    Post by Guest Mon Jan 19, 2009 5:44 pm
    Does anyone know another radiator that might fit in a 1963 econoline? Mine has filled up with rust and sludge from hell for sitting the past 12 years. New help, thanks
    radiator retro fit Empty Re: radiator retro fit
    Post by G-Man Mon Jan 19, 2009 5:48 pm
    Have you priced having your stock one recored???
    radiator retro fit Empty Havent thought of that
    Post by Guest Mon Jan 19, 2009 5:51 pm
    I never thought of that do you know how much that usally costs. Im trying to keep a little in my pocket to feed the family, Thanks,Pork
    Post by G-Man Mon Jan 19, 2009 6:01 pm
    You'll have to check your local shops for that. This way you'll have the right one that will fit. It would be all new core with your old tanks
    Post by Guest Tue Jan 20, 2009 4:53 am
    I have a local shop do my A-100 radiators. Generally costs about $375 to $400 for a recore.
    Number of posts : 1605
    Post by itruns Tue Jan 20, 2009 6:49 am
    nate the skate wrote:I have a local shop do my A-100 radiators. Generally costs about $375 to $400 for a recore.
    Ok, so the quote I got to do mine last year wasn't quite so bad. I truely thought the guy was torquing with me.
    Number of posts : 7900
    Post by DanTheVanMan Tue Jan 20, 2009 6:54 am
    We have one here too. They charge between $325 to $475 depending on the model. Or $225 to $275 for a recore.
    radiator retro fit Qr_cod10
    Post by Guest Tue Jan 20, 2009 1:47 pm
    Seems high, BUT the place I deal with uses "extra" duty cores that hold the capacity of a 4-row, but take up the same amount of space as a 2-row. All copper/brass construction. They do a fine job. I don't mind paying for quality.
    Slowride
    Number of posts : 67
    Registration date : 2009-02-17
    Post by Slowride Tue Feb 17, 2009 5:34 pm
    Get a radiator for an early Falcon and have the shop solder your side brackets on, or just flip the new ones. Did it on my son's '63 and looks and fits like original.
    Number of posts : 987
    Post by RipVanArkie Tue Feb 17, 2009 8:47 pm
    From what I can tell, a rad from a Maverick/Comet should fit as well. Might have better luck finding one at the local pic n pull.
    Later,
    Rip
    Post by Guest Thu Feb 19, 2009 4:17 am
    Thanks for the info. I scouted around the local auto recycle places but couldn't find any to fit . got a few quoates on the net that were in the 300-400 range . I wasn't worried about keeping it stock so after i check around on ebay I found a new aluminum thats for a 32 ford coupe that should fit. For 200.00 I just gotta get some hose sections for it. The upper outlet is 1 1/2 and the lower is 1 3/4 that i should be able to find at the junkyard pretty easilly. Thanks again
      Current date/time is Sat May 18, 2024 6:00 pm
