I BOUGHT A 1970? CHEV VAN THAT SOMEONE MADE INTO A CAMPER VAN THEN ADDED MORE GAUGES TO IT LIKE OIL TEMP,TRANS TEMP,TACH,AND VOLTAGE AND OF COURSE NONE OF THESE WORK BECAUSE SOMEONE BROKE IN AND STOLE THE RADIO BUT TORE THE DASH UP IN THE PROCCESS HAVEN'T BEN ABLE TO FIND A REPLACEMENT DASH OR A WIRING DIAGRAM FOR ALL THE EXTRA STUFF ANY IDEAS I THINK IT IS A G OR C 20 THE 0 PART IS RIGHT NOT SURE OF THE C OR G THOUGH MARKAM
WHAT IS IT
Scott- Number of posts : 1651
Re: WHAT IS IT
If they are aftermarket gauges you might find the install directions on their website. I used Sunpro gauges and was able to download the directions before I bought the gauges. I went ahead and ran the wires for everything at once, then later went back and bought the gauges.
Re: WHAT IS IT
if there are any brand/maker names on the gagues?? Google about them. Usually all aftermarket gagues use same value senders also. the wires on the back- depending on type gague will usually be 1 =gague lite 1=power to gague & 1= wire to sender. except volt & amp gagues -diff. Thats for all electric gagues - mechanical gagues are diff .
Re: WHAT IS IT
Re: WHAT IS IT
