    Pro's and Con's of Bottom pan ON or OFF?
    Number of posts : 277
    Registration date : 2011-01-20
    Pro's and Con's  of  Bottom pan ON or OFF? Empty Pro's and Con's of Bottom pan ON or OFF?
    Post by Lyrad Tue Oct 23, 2012 8:13 pm
    Howdy All,
    Im not sure of the name of the bottom sheet metal tray that bolts onto the under side of early vans or if it has a name.
    Who out there know of the Pro's and con's of run the van with it ON or OFF ?
    When I bought my van it didn't have one on it, but I have since found one that is in good shape, I'm not sure if I should put it on. Is thier a good purpose for them? Air Flow, looks, protection, extra weight, tool catcher.....WHY?
    Number of posts : 1686
    Pro's and Con's  of  Bottom pan ON or OFF? Empty Re: Pro's and Con's of Bottom pan ON or OFF?
    Post by westcoastvanner Tue Oct 23, 2012 10:04 pm
    It's called a belly pan and it is designed to force the air, through the radiator to keep the engine running cool.
    Number of posts : 134
    Registration date : 2011-02-26
    Post by wildbillinva Wed Oct 24, 2012 2:39 am
    also offers some radiator protection from road debris.
    Post by Digz Wed Oct 24, 2012 3:25 am
    My vote is mostly radiator protection. Most of us are fair weather drivers. If you have ever put one of these in a snowbank without the pan you end up with an iceblock in the doghouse.
    Number of posts : 3046
    Post by RodStRace Wed Oct 24, 2012 7:09 am
    I bow to Occam's razor on this one.
    If the factory spent the time and money to design, manufacture, and install these, that is a good reason to reinstall one.
    The only time I drove one without a belly pan for a long distance, the engine holed a piston. Was that the cause? Probably not. The engine was tired, the day was hot and it was the first time I'd driven it long distance on the freeway. I won't do back-to-back testing to prove it.
    Unless you are in the middle of a project that requires it's removal, why not install it and keep the airflow up and debris out?
    Number of posts : 1778
    Post by m1dadio Wed Oct 24, 2012 11:39 am
    I don't have one onmy 65, Based on my aerodynamics education I think they are designed wrong as far as airflow goes. They probobly will protect the rad somewhat.
    I havn't seen any difference in cooling on or off except they are very in the way when it comes to working on my van.
    M1D
    Post by Lyrad Wed Oct 24, 2012 5:38 pm
    I am thinking along the same lines as M1D. This is my third early, my 65 had the gut pan on it but I took it off to work on the rad and it never went back on. My 68 never did have it when I bought it, so I'm thinking some one did the same thing I did on the 65......So on the fence I sit....ON or OFF.
    Is the belly pan on your Van, do you like the complete orginal stock look or What Ever?
    Donn
    Donn
    Number of posts : 692
    Post by Donn Wed Oct 24, 2012 6:45 pm
    I have a v8 and the belly pan keeps IN to much heat in the summer. Running without I get a lot more dirt and dust on the motor / dog house. I have put it back on now that the summer is over and so far no heat problem and a much cleaner engine.
    I would say in you are running a 6 you should have it
      Current date/time is Wed May 08, 2024 1:23 pm
