neondv8
    transmission cooler
    neondv8
    neondv8
    Number of posts : 278
    transmission cooler Empty transmission cooler
    Post by neondv8 Fri Sep 14, 2012 10:39 pm
    Who has a transmission cooler? And how do These things work? And whats a good spot to put?
    I have a c-4 in my 66 e-100. I
    Just did the radiator fan, and now I'm all hot to cool the transmission off !
    Hahaha.
    Number of posts : 387
    transmission cooler Empty Re: transmission cooler
    Post by whopman Sat Sep 15, 2012 2:30 am
    I put one on my 66 Chevy...has an inline thermostat to kick fan on when needed. Powered off the ignition circuit.
    transmission cooler Img_0210
    transmission cooler Img_0211transmission cooler Img_0610
    Number of posts : 1279
    Post by Space Truckin Sat Sep 15, 2012 6:21 am
    Whopman
    Part numbers and $
    Post by Digz Sat Sep 15, 2012 7:04 am
    I'm running one of the aluminum finned tubes. I can give you no real input other than I haven't seemed to cook my tranny yet. It is the longest one I could find at about 34 ". No moving parts.
    transmission cooler Transc10
    Post by Big W Sat Sep 15, 2012 11:08 am
    It's in, but not its final setup. Hooked to a TH350. Once I am ready for final assembly I will make nicer brackets and a rock deflector as well.transmission cooler Trans_10
    Donn
    Donn
    Number of posts : 692
    Post by Donn Sat Sep 15, 2012 9:05 pm
    I put mine just behind the front grill where it gets a very good air flow, no fan needed.
    Some of these set ups look like they will have poor or no air flow. All radiators need air to work correctly. To reach the grill you will need longer lines to reach trans but they are cheaper then buying a fan that you really dont need.
    neondv8
    neondv8
    Post by neondv8 Sat Sep 15, 2012 9:18 pm
    Lots off good info!
    But what are the two lines going to the trany?
    And how is it keeping it cool?
    Post by whopman Sun Sep 16, 2012 4:43 am
    derale cooler purchased from summit racing # DER-15820 $145.95
    derale inline thermostat from summit racing # DER-35021 $44.95
    The unit is on a th350 chevy the two lines are in and out that would normally go the the bottom of a radiator. I have had no issues with this set up.
    When installing the inline thermostat be careful not to over tighten..
    Had the lines made at a local hydraulic supply store..
    The lines cost around $30 bucks a piece can't remember exactly..didn't want to use rubber lines or bend more tubing..i think you can order lines pre-made from summit as well can't remember the cost though.
    Murdock
    Murdock
    Number of posts : 313
    Post by Murdock Sat Dec 29, 2012 12:30 pm
    I just recently went with the Derale with thermostat as well. Since I have a side step I put mine in front of the right rear wheel well. I ended up welding in a pair of 3/4" angle iron. I left enough space on top for air to flow in. I painted the exposed metal with Eastwoods for now. I will eventually be fixing a couple of PO drilled holes in the floor and undercoating this area but I wasn't about to open a that can of worms yet. (If you right click on the images below and select "Open in new tab or window you will see the entire image).
    transmission cooler Attachment
    transmission cooler Attachmenttransmission cooler Attachment
      Current date/time is Sat May 11, 2024 11:15 pm
