So I took my van all apart. I thought I labeled everything really good. I sent the springs out had the rears rearched. Now I'm trying to put the rear end back and the spring shop made one of two mistakes,either they put the pressed in groomets on the wrong end of the spring or they rearched the front instead of the rear. HOW DO YOU TELL THE DIFFERENTS BETWEEN THE FRONT AND REAR SPRINGS ??? On one set there is a bigger collar on one end, is this the front or the rear ? Thanks for any help.
gkpost
leaf springs ?
Re: leaf springs ?
On one set there is a bigger collar on one end, is this the front or the rear ? Thanks for any help. [/quote] i have heard several people comment on fronts having 2 different sizes.
Re: leaf springs ?
look at the center pin holes in the spring,,,,,they aint in the center,,,,,,the longer side of the spring from there goes towards the bumpers,,,,
gkpost- Number of posts : 224
Re: leaf springs ?
I think the spring shop rearched the fronts instead of the rears. Fortunetly I didn't do such a great job wire brushing the springs before I painted them and once I stoped being so pissed off, and took another look. I could see the difference in the u-bolt marks. so I have to say the bigger collar set of springs is the rear. If anyone has different info let's hear it. But I think right! Thanks to all GK
Re: leaf springs ?
The collars go in the perches,,,,the cartridges go in the perches,,,,,the collars on the rear springs are the short sides,,,,the collars on the front springs are the long sides,,,,,,measure the distance from the center bolt to each end of the spring,,,,,,there is a short side and a long side,,,,,,
CraigK- Number of posts : 141
Re: leaf springs ?
Donivan
I think you are trying to explain which end of the spring goes front to rear when installing on the axle but I get the feeling that GK is trying to figure out which set of springs is for the front axle and which set goes to the rear. Maybe I am reading it wrong
Craig
Craig
Re: leaf springs ?
I'm trying to figure out which set is front springs and what set is rear springs.There is a difference one set has a bigger collar on one end.
Re: leaf springs ?
Went out and looked at mine (2nd gen)the front springs have the same size loops.... and the rear has the one larger loop that goes toward the front(not the shackle side)
Re: leaf springs ?
I am saying the springs go on 180 degrees different,,,,,,on a 1st Gen, there is a 22 inch end and a 26 inch end,,,,(the drive shaft wants the 22 inch end,,,,,the front bumper wants the 26 inch end),,,,so you need to identify each end and THEN see if they put the bushings in the right end,,,,,the front spring is 26 inches,,,if you put it on the rear,,,you will find your driveshaft is 4 inches too short,,,,so 1st sort out what you got,,,,,see if they just grabbed another leaf or put the bushing in the correct side,,,,,,the front and back springs are not the same ,,,,they go on a certain way and the bushings go on a certain end,,,,,just see if they did not mix everything up
Re: leaf springs ?
Thanks for all the help. I had the direction of the srings right. I couldn't figure which set were front or rear. I had the shop press in bushings on all 4 springs and rearch the rears. They rearched the fronts and that's where I got confused. So now my van will be 1 inch taller in the front for a while. I just want it on the road, So to keep things straight, The set with the bigger collars are the rear and the big collars go forward of the axel.
teamthunder7- Number of posts : 13
Registration date : 2012-02-17
Re: leaf springs ?
Go to detroit springs I just wanted to add that you stated that you painted your springs.You really should never paint your springs as this will weaken them over a period of time.If you find this crazy call detroit spring and they will tell ya.Just like oil will do the same thing.
