I am looking to swap to disk brakes on the front of my 65, how hard is this and what vehicle should I get the parts from? Any help would be greatly appreciated. Thanks
Hellfish
pilotmtnraider
Disc Brakes???
pilotmtnraider- Number of posts : 65
Registration date : 2008-05-30
Disc Brakes???
Hellfish- Number of posts : 146
Re: Disc Brakes???
I got a kit from D&D. Super easy. Vic aka "OldSkool" also makes/sells a kit that's really nice.
Lots of swapping articles online.
If you search online you will find there are disks that will swap on, but will require a lot of scrounging and fabrication, e.g., AMC disks, with calipers from something else and spindles and brackets from something else.
Rayallen- Number of posts : 648
Re: Disc Brakes???
I went with D&Ds disc brake bracket and dual master cylinder. Its not hard to do but be prepared to spend some money. All said and done I spent around $1100 with new brake lines that not bad.
Use the search button on the site and type in Disc Brakes and you will see a lot of topics on this, just make sure you are looking at econolines. Will not be the same for the Gs and A100s
Re: Disc Brakes???
I just used the D&D kit, plus a Maverick dual MC and I purchased a bracket. I clocked in at well under $500.
Re: Disc Brakes???
Looks like they have made changes to the site.
http://www.dddiscbrakes.com/kits.html
to stay way under $500 you must have been able to find some damn good deals. I spent $600 with Dennis on the Basic kit and his Loaded Master Cylinder kit and once I bought new brake lines, rotors, calipers, remote reservoir etc I was at the $1000 mark counting in extras. I did not buy anything used.
Re: Disc Brakes???
Oops, I looked at the wrong line. Probably in the $600-$700 range.
gearheadflicks- Number of posts : 32
Registration date : 2012-04-19
Disc Brakes update
Hi guys i'm also looking to convert my brakes. I'm checking out dddiscbrakes.com and I've emailed them some questions... maybe you guys can shed some light on the topic. I'm kind of in the dark.
Q1. Does the kit dual master cylinder attach into the existing location right at the brake pedal and emergency brake pulley mounts?
Q2. What existing items are used in this D&D conversion?
Q3. Does anybody have photos of their D&D conversion?
Q4. Should I have rear discs?
Q5. Does the D&D conversion allow room for modern wheels?
Q6. Does anybody know how wide of a tire that can fit within the well?
thank you for any info guys!
Last edited by gearheadflicks on Sun Aug 26, 2012 11:43 am; edited 1 time in total (Reason for editing : additional question)
econoaddict- Number of posts : 42
Registration date : 2012-06-15
Re: Disc Brakes???
A1. It uses the stock position, some econos require a small area on the ebrake bracket to be trimmed.
A2. The stock spinlde and hub are retained. As well as the hard lines.
A3. Somebody posts some pics please
A4. This is totally up to you. A 9" rear with drum brake will be plenty along with front discs.
A5. So far we have had no issues that I am aware of with 14" or larger aftermarket wheels.
A6. I can't really answer this, I have never actually tried to see how wide I can go.
SDEconoTruck- Number of posts : 310
Re: Disc Brakes???
Here's a pic of mine:
I'm using 17 x 7. I got 205's but it seems 215 tires can fit with full steering without hitting. BUT, I have a narrowed axle because I had the axle dropped, it is 3/4" narrower on each side. I can get offeset info for the rims if needed.
Also notice the sway bar, I custom fabbed it, there is potential for interference between it and the caliper. Dennis was concerned and sent me a set of his shock mounts and followed up with a couple of phone calls. I ended up using the stock lower link location but like I said it is pretty f-in tight in there...
Re: Disc Brakes???
Thank you for your response guys! Anything else can still help!
Re: Disc Brakes???
Here is my current build thread. Start at page 11 and you will see I have done the Disc brakes, Master Cylinder, remote brake fluid reservior and new brake lines.
https://vintage-vans.forumotion.com/t22639p150-bought-a-1964-econoline-today
Good luck and have fun..
