    Headlight Relay
    Number of posts : 1651
    Headlight Relay Empty Headlight Relay
    Post by Scott Fri Aug 03, 2012 8:43 am
    I've been running on an internally regulated 75amp Alternator since I go the van on the road early this year. Electrically nothings been added, just the basic no radio van with whatever it came with from the factory.
    The problem I'm having is when I turn the headlights on the Generator light starts to glow. When the headlights are on, and I use either Blinker, the Generator light pulses with the light. So I know it's not just a dash bulb put in the wrong place.
    A friend at work suggested I put a headlight relay in, that the problem has something to do with the Headlight switch in the dash. I'm not convinced, so I'm bringing it the experts..
    That would be y'all
    Headlight Relay Empty Re: Headlight Relay
    Post by Nightmoves Fri Aug 03, 2012 10:18 am
    Just off the top of my slick head...
    check your grounds.All of them.
    Post by donivan65 Fri Aug 03, 2012 10:31 am
    I am thinking the connectors on, and to, the printed circuit board are loose or dirty,,,,,,
    Post by Digz Fri Aug 03, 2012 2:21 pm
    unplug the bulbs in the little lights..lol
    Number of posts : 1778
    Post by m1dadio Fri Aug 03, 2012 6:10 pm
    First
    What Night moves said
    and don't just look at the grounds (especialy arounf the dash) disconect them and clean them.
    M1D
    66BC
    66BC
    Number of posts : 159
    Post by 66BC Thu Aug 09, 2012 12:38 am
    Speaking of Head light Relay...Can someone post a diagram how they wired that type of set up on. I have upgraded my wiring with just fresh wiring, inline fuses and bigger gauge and wiring for Internally regulated alternator but I haven't upgraded the alternator yet. I'd like to do the relay wiring. how to please? And what else have you guys put relays on or added to your wiring as upgrade?
    Number of posts : 3046
    Post by RodStRace Thu Aug 09, 2012 6:23 am
    wiring
    http://audi.humanspeakers.com/headlight-simple.htm
    a couple articles you should read
    http://www.madelectrical.com/electrical-tech.shtml
    They also offer a relay kit
    Post by Scott Thu Aug 09, 2012 8:07 am
    Thanks,
    I haven't had time to work this out yet. I've been spending all my spare time getting the house ready for my daughters graduation party, and hopefully to move in the next 6 or 7 months. Oh, and then there's a couple of hundred feet of fence I'm replacing..
    Thanks for the links, I'll look them over tonight. There's some good stuff in this thread, I just need to make time to try it.
      Current date/time is Mon May 13, 2024 5:08 am
