    ignition switch
    back2thewoods
    back2thewoods
    Number of posts : 842
    ignition switch Empty ignition switch
    Post by back2thewoods Sun Jul 22, 2012 5:28 pm
    my dumbass nephew , disconnected ig. switch to replace, i need a simple explanation on where the wires go, im also running aftermarket gauges. red is bat, pur. is solinoid, pin, ign. brn, white, do i need to hook up , with running gauges?
    Number of posts : 890
    ignition switch Empty Re: ignition switch
    Post by jrinaman Sun Jul 22, 2012 8:35 pm
    just went threw this last week. the 'extra' wire is for power on 'accessary' everything worked fine without it, and most of my stuff is already wired to work without key. only thing it does is light the dummy lights in dash if key is on while not running.
      Current date/time is Wed May 08, 2024 12:20 pm
