    largest wheel size
    ericdigital
    ericdigital
    Number of posts : 7
    Registration date : 2012-02-23
    largest wheel size Empty largest wheel size
    Post by ericdigital Tue May 22, 2012 11:09 am
    What size wheels can I put on a stock suspension 1965 dodge a-100?
    I am looking at these wheels on craigslist but they seem wide .....15x7.
    here is a link to the wheels.
    http://cnj.craigslist.org/pts/3016119486.html
    will these fit?
    Id like to get them today so any help would be much appreciated.
    Number of posts : 3046
    largest wheel size Empty Re: largest wheel size
    Post by RodStRace Tue May 22, 2012 5:38 pm
    This is a very common question for all sorts of vehicles. I understand that it's tough to measure and take into account suspension loading, but if you spend a little time on here looking at all the posts, you will get a good idea.
    This guy just installed 18 X 7.5 Challenger wheels on his...
    Is yours at the same height?
    Do you have the same clearance on both sides when you try the same wheel on each side?
    What are you willing to do to fit big stuff?
    largest wheel size Normal_100_2557
    Post by Digz Tue May 22, 2012 5:49 pm
    15x7 will fit almost anything unless they have some wierd backspace. from there its tire size.
    Number of posts : 8732
    Post by dix Tue May 22, 2012 6:32 pm
    15 X 7 WILL FIT UNDER THA A100'S WITH A 4 INCH BACKSPACE. 3 1/2 IS MORE COMMON
    Stoopid john
    Stoopid john
    Number of posts : 265
    Post by Stoopid john Tue May 22, 2012 6:43 pm
    The wheels i took off were 8.5 wide (all the way around) and they had alot of room.
    largest wheel size Normal_100_1420a
      Current date/time is Sun May 19, 2024 7:00 am
