    Bad vibrations
    Bad vibrations Empty Bad vibrations
    Post by Guest Sat May 05, 2012 4:52 am
    My van vibrates with a 250 six and TH 350 vibrates at idle in drive or reverse, it is good and smooth in park or neutral and under acceleration. Its really annoying as anything that can rattle or shake makes noise. Where should I start looking?
    NipRing
    NipRing
    Number of posts : 336
    Registration date : 2011-08-14
    Bad vibrations Empty Re: Bad vibrations
    Post by NipRing Sat May 05, 2012 4:59 am
    I have the 230 with a 700r4 and its pretty much the same thing.
    Post by Twinpilot001 Sat May 05, 2012 6:40 am
    bushing wear in tailshaft area.
    Post by Guest Sat May 05, 2012 7:43 am
    Do you mean a bushing inside the transmission?
    Number of posts : 1778
    Post by m1dadio Sat May 05, 2012 8:36 pm
    I would bring it to a very good trans diognostic person for an oppinion.
    What you descride could be a torque converter issue since "at idle" while under load of first or reverse the torque converter inner parts are at maximume speed differential. IE the trans imput shaft is held at a stop and the rest of the torque converter is doing engine idle speed. At no other time is the speed difference between torque converter parts greater.
    M1D
    Number of posts : 801
    Post by panelmanrd Sun May 06, 2012 7:05 pm
    how fast is the idle rpm in drive or reverse?
    and how old are you motor mounts? [not broken, just
    old and stiff not letting it flex].
    Post by donivan65 Sun May 06, 2012 7:38 pm
    When it is rattling, take the air cleaner off and spray some carburetor cleaner down the carburetor and see if that changes the noise,,,,,,
      Current date/time is Sun May 12, 2024 8:23 am
