Does any one have a source for the paint used on the slant 6 from a 64, Mine was yellow and I'd like to go with the original color. I'm having trouble finding out what it was called. Any of the off the shelf rustoleum close?
Industial yellow paint, slant 6
Re: Industial yellow paint, slant 6
Welcome to the site, here's a link to the place I used to get my paint.
http://sdparts.com/details/mopar-performance-parts/p4529144
And here is the color chart with the paint numbers
http://www.cowtownmopars.com/EngineColors.html
No problem, if you can't find a part or have troubles ask away. The guys on here have helped me out a bunch of times.
This site is going to be a great resorce!Thanks again, Ray
- Number of posts : 8729
welcome to v.v. i don't think mopar ever used yellow for the engine. altho I did paint mine yellow just to stand out. Just make sure yoy use engine paint and it's clean of oil and dirt before you paint it.
can you post a pic? summit has yellow. when you say "industrial" do you mean orange/yellow like on some heavy equipment and school busses?http://www.summitracing.com/parts/VHT-SP128/
like these?http://www.industrialtouchup.com/caterpillar.aspx or thishttp://www.jamestowndistributors.com/userportal/product.do?part=133795&engine=adwords!6456&keyword=product_ad_55151&type=pla or this?http://www.tractorpartsinc.com/caterpillar_equipment_enamel_paint_354_ctg.htm
Last edited by jrinaman on Sun Apr 22, 2012 8:52 pm; edited 2 times in total (Reason for editing : added more info)
http://www.turbinecar.com/misc/enginecolor.htm just found this, 1960-67 chrysler slant 6 in yellow!!http://www.houstonmopars.org/specs/moparmotorpaint.jpgok, found it. is this what you have?http://www.sweptline.org/forums/viewtopic.php?f=5&t=22205&start=40
The mopar performance part number is correct, but they discontinued the paint! Found a dealer in Calif. who has 9 cans but can't ship it because it is hazardous material. Called a body shop supply company and they need a paint number from a known paint supplier (Dupont, Ditzer,etc.) to mix it.One site said John Deere yellow was a very close match? With the paint that is left on my motor its hard to tell. I didn't think it would be this difficult, I'm not a perfectionist, but I'd like it close to the original. Its the chase that makes it fun, Right?
Ya, guess we have some of the only yellow ones left. They were /6 truck engines from 60-69. Still looking for someone else to get it from. I don't know why the guy won't ship the paint to you? Fedex and UPS do hazmat all the time with the right paperwork.
I found a rustoleum color that is very close to the color on some of the parts I've cleaned up. Its rustoleum painters touch warm yellow #249091 .
the paint you should use would be a engine paint or a hi temp paint .
jkr- Number of posts : 1148
yellow was used for sure Dix and if i ever see another i best have a magnet on me. i believe some of the very rare alluminum block slantys were painted yellow so look close if you see one.
Mine is painted yellow but I don't know what color yellow was on the /6. and jeff thanks for the tip on the /6 yellow blocks, thats very interesting,
My mom's '61 Lancer had an aluminum block. It wasn't Yellow though. I don't know if that was a truck thing...
HeyRay, if you can't find a decent match locally, you can post the dealer info and see if there is a member locally that would be able to go buy a can or two and ship it to you.
I'd suggest getting a modern catalyzed paint for the engine if you have access to the equipment and safety gear. The engine stuff in cans is okay, but you can't beat the shine and durability of a decent single stage 2-pack. Even better if you use a catalyzed clear.
I read long ago that engine paint is nothing special, Getting the surface prepped and clean will make the biggest difference. I've painted many engines with off the shelf paints and had no problems.
