i need some part numbers, id love some that say wipers and lights, maybe interchangable for hotrods? for a 64 chevy, thanks
headlight switch, wiper switch
back2thewoods- Number of posts : 842
Re: headlight switch, wiper switch
thanks donivan, and wiper switch?
So what kind of wiper motor do you have? The original is a 1 speed,,,a wire from the fuse goes to the motor and 1 wire comes up to the switch which just grounds it to make the wipers move,,,,and do you have the bezel and knob for an original headlight switch? And chances are pretty good you will find the switches on a Corvair Parts Site, since thats what these dashes are from,,,,,
1 speed
when i replaced mine, i went with a 2 speed wiper motor. but never upgraded switch. any idea on switch and how to wire it?
The wiper motor probably has a yellow wire to it from the fuse box fuse,,,,,,the rest of the terminals need to be grounded to make it work,,,,,so the switch has to be in the dash and the dash has to be installed for the switch to work. The switches come in 3 flavors,,,1 wire for a 1 speed,,,,2 wires for a 1 speed with the windshield washer pump built on the wiper motor and 3 wires for a 2 speed with windshield washers,,,,so basically you need to match the switch to the motor,,,,,,,,,the switch for washers have a push button in the middle of the knob,,,,
any source for 1 speeds?
Not to thread jump,but on related subject,for future search purposes...
Anybody know a part # or cross reference for the washer pump on the two speed wiper?
Nightmoves wrote:Not to thread jump,but on related subject,for future search purposes...
So Moe, is the pump bolted on the motor or part of it? and do you have a good washer bottle for it,,,,,they probably make new little electric pumps to spray the windshield,,,,,,
