    AC Aftermarket in my E100 Pickup
    Number of posts : 864
    AC Aftermarket in my E100 Pickup Empty AC Aftermarket in my E100 Pickup
    Post by Casimier Fri Mar 16, 2012 12:53 pm
    Some of you already know that I've always wanted AC in my pickup...
    Hell, that's why I put the big torque 300 cu in engine in instead of the 240. Well, after seachin on Ebay and Craigslist I got lucky and found a used after market unit really cheap. I wish that I had a $1000 to fork over for an exact match unit from Vintage Air but I didn't. I blew the exhaust manifold gasket so it was a good time to start the AC install. The following install will come to you in parts...or should I say problems....
    Problem #1
    How do I mount the sanden compressor on the passenger side of the 300 motor? There is no bracket made for this application. Guess who made one out of an alternator bracket I had laying around.
    Here are a few pics of the passenger side of the engine showing the alternator bracket chopped on the upper left to clear the manifold and chopped along the lower right to clear the water pump hose.
    [img]AC Aftermarket in my E100 Pickup 1_3-6-14[/img]
    [img]AC Aftermarket in my E100 Pickup 2_comp10[/img][img]AC Aftermarket in my E100 Pickup 3_comp10[/img][img]AC Aftermarket in my E100 Pickup 4_comp10[/img]
    Last edited by Casimier on Fri Mar 16, 2012 1:00 pm; edited 1 time in total (Reason for editing : pictures)
    AC Aftermarket in my E100 Pickup Empty Re: AC Aftermarket in my E100 Pickup
    Post by Casimier Fri Mar 23, 2012 12:54 pm
    So, my buddy comes over with his welder and welds a couple of brackets under the truck just rear of the passenger seat.
    Econocarl gave me the idea to locate my condensor under the truck and out of the way. The AC lines were just the right length. The fan wires will be jumped to the compressor switch. Here are a couple of pictures. The fan works as a pusher.[img]AC Aftermarket in my E100 Pickup Conden10[/img][img]AC Aftermarket in my E100 Pickup Conden11[/img][img]AC Aftermarket in my E100 Pickup Conden12[/img]
    Post by donivan65 Fri Mar 23, 2012 10:55 pm
    I don't know about that fan sucking up all the junk off the road and shooting it into the condenser,,,,,the one I did has the fan on top and it blows down,,,,
    AC Aftermarket in my E100 Pickup Harry_45
    Post by Casimier Sat Mar 24, 2012 4:00 am
    Don
    You make a good point. Since you've had your AC in longer and have had no
    problems , I'm going to go with your expert opinion and switch the fan around.
    Thanks for the look.
    Jim
    Post by donivan65 Sat Mar 24, 2012 8:48 am
    I think the front tires would be throwing up rocks and dirt and it would be sucked in and hit the the fan blade.
    Post by Casimier Sat Mar 24, 2012 7:32 pm
    I'm going to switch the fan on top and then put some wire lath to cover the condensor...
    that should do it.
    66ThunderVan
    66ThunderVan
    Number of posts : 384
    Post by 66ThunderVan Sun Mar 25, 2012 10:07 am
    I mounted mine at a 45 degree angle between the panel under the side doors to the junction of the frame rail and floor. I made a scoop to draw air in and over the condenser and mounted a fan on the under side.
    Post by Casimier Mon Mar 26, 2012 5:26 am
    Hey Thunder
    Got any pics of that mounting technique?
    Thinking of having a Northeast Early Gathering sometime in July up here in Jersey...think you might come?...trying to get some kind of head count.
    Jim
    66ThunderVan
    66ThunderVan
    Post by 66ThunderVan Mon Mar 26, 2012 2:25 pm
    I don't have any pics, other than the one in my sig. That van was retired in 1980 due to a broken frame and the body I transfered the parts into did not get the AC. I will try to mock up something this weekend and take pics to show the idea. That setup got plenty of airflow and never had any issue with rocks, even though the scoop was directly behind the front wheel. At highway speed the fan was not needed and got turned off to lighten the load on the charging system.
    I am trying to get my van running for Carlisle and if I get it done I might be able to attend. It has been a work in progress for longer than I want to admit.
    Linoman
    Linoman
    Number of posts : 329
    Post by Linoman Thu Apr 26, 2012 6:23 am
    Casimier ~Any updates on your AC install?
    Post by Casimier Tue May 01, 2012 11:38 am
    OKAY..the AC is finished and it WORKS!
    Here are a few pics of the install....[img]AC Aftermarket in my E100 Pickup 11_com10[/img]
    This shows the compressor with too mucjh plumbing...as it worked out, I did not need it..
    [img]AC Aftermarket in my E100 Pickup 13_com10[/img]
    This pic is a view of the compressor looking towards the passenger side.
    Notice that the plumbing is removed..I was able to loop the heater hoses over the new bracket that is bolted to the exhaust manifold.
    This next pics are of the dryer/cannister which was mounted behind the grill just next to the horn. AC lines just followed the heater lines.
    [img]AC Aftermarket in my E100 Pickup 1_drye10[/img] [img]AC Aftermarket in my E100 Pickup 2_drye10[/img]
    I cut a couple of hose holes in the floor just left of the heater hoses and the AC lines worked in just fine. Here is a pic of the AC unit side and then the final cabin pic. Maybe I'll have some how to pics on the clock and the radio console some other time.
    [img]AC Aftermarket in my E100 Pickup 1_ac_s10AC Aftermarket in my E100 Pickup Ac_uni10[/url][/img]
    [img]AC Aftermarket in my E100 Pickup Cabin_10[/img]
    [img]AC Aftermarket in my E100 Pickup Ac_uni11[/img]
    Number of posts : 648
    Post by Rayallen Wed May 02, 2012 2:05 pm
    Awesome! Great job. Ready for the summer.
      Current date/time is Fri Apr 26, 2024 8:07 pm
