mcfly
    Seat install (cut wheel well) ????
    mcfly
    mcfly
    Number of posts : 626
    Seat install (cut wheel well) ???? Empty Seat install (cut wheel well) ????
    Post by mcfly Thu Mar 15, 2012 4:58 pm
    While the van is all apart I was thinking I might lower the front seats a pinch.. I have Miata seat and the sit a little high..
    Has anyone cut the front wheel wells a couple of inches to lower seats.?
    If so what problems if any did you incounter?
    Number of posts : 1868
    Seat install (cut wheel well) ???? Empty Re: Seat install (cut wheel well) ????
    Post by HandiVanMan Thu Mar 15, 2012 5:14 pm
    Don't think that it would be a good idea.
    Post by Digz Thu Mar 15, 2012 5:59 pm
    I know on the chevys the upper shock mounts are at the inner curve, does the fords work the same way? Could you just channel it at the seat rails to gain enough?
    Number of posts : 655
    Post by 61econoline Thu Mar 15, 2012 8:22 pm
    I did it on an econo pick-up and plan to do it on my econo-van.i just cut a section for the seat rail sit in cut two lines with a cut-off wheel ,bent the section down, and welded in some sides.made a nice pocket for the seat rail to sit in.
    Hellfish
    Number of posts : 146
    Post by Hellfish Fri Mar 16, 2012 9:38 am
    You might need shorter shocks if you do
    Number of posts : 864
    Post by Casimier Fri Mar 16, 2012 9:56 am
    Mike
    Maybe it's the seat?
    mcfly
    mcfly
    Post by mcfly Fri Mar 16, 2012 12:10 pm
    Casimier wrote:Mike
    Jim,are you saying my a$$ is too big..? Laughing
    Van is at my buddies (I go there every Sat. to work on it)so I will take a look at it tomorrow and access what needs to be done..
    Post by Casimier Fri Mar 16, 2012 12:28 pm
    YOU ARE TOO FUNNY!
    Hey, I was so excited when I got these Mercedes C230 seats...
    lumbar support...electrrical adjustment...motors and everything...
    DID NOT FIT...TOO HIGH!
    had to rip the automatic stuff off the bottom, could not use the stuff...
    so I kept the seats and mounted them to the econoline brackets...
    so you know, I have a pair of cloth buckets for sale that came out of my 65 donor.
    So, what do you think about THE NORTHEAST GATHERING OF EARLIES?
      Current date/time is Sun May 19, 2024 10:44 am
