My Van: 69' G20 3/4ton 307/th350
The van starts & idles just fine but as soon as I put it in gear it stalls the motor. It will start right back up as if nothing is wrong.
I can get to stay running in gear using the choke. Once the van is driving I can return the choke to off & the van seems to drive fine (max speed so far 50mph) until I come to a slow crawl or stop & then the motor dies but will start right back up without hesitation. What kind of problem should I be looking for.
I've checked or replaced:
carburetor
cap, rotor, condenser & points
plugs & wires
set timing
thanks for any help.
carburetor
plugs & wires
set timing
