I just picked up the built 300 I mentioned in my last post. It is an 81 model with an Offy C-Series intake and Hooker Competition headers. Has a bigger cam, but the seller didn't build the motor, so he didn't know the specs. He could only say that it was pulled out of a running 85 F150 in January of this year and kept in his garage ever since. When asked how it ran, his exact words were;"no knocking,smoking, real lopey idle and pulls like a mule!
Engine is very complete, (minus a carb) even still had power steering pump and other accessories that I may not need. I was able to get it for $425, so I feel that is a good buy.
Will the rear sump pan cause problems with the install in my 67? Can I just use a 67 water pump to connect to my radiator? I'm already aware of the mods needed to the dog house. Considering running a 600 Holley on it. Is there any other things I need to worry about before starting the swap?
As always, thanks to you guys for your inputs, photos and info!
