+8
kayjsharp
kykayaker37
white-lightning
12 posters
Devimaus 69 108
Devimaus 69 108
Re: Devimaus 69 108
So what did the machine shop do to that new engine that you had built up ?
Re: Devimaus 69 108
dipped the block to eliminate rust.
installed new freeze plugs.
machined crank and rods...new journals and rod bearings.
replaced cam bearings...new cam and lifters.
new alu timing gears.
bored and honed cylinders... .30 over with 307 flat top pistons to bring up compression to 9 to 1 aprox, molly rings.
machined the head...new valves,seats, springs, guides, seals.
Re: Devimaus 69 108
Let us know how she runs after you get it going
Re: Devimaus 69 108
Re: Devimaus 69 108
Big W- Number of posts : 3282
Re: Devimaus 69 108
That's coming along nicely. Keep up the most excellent work.
Re: Devimaus 69 108
Nice progress.
Re: Devimaus 69 108
That is a whole lotta effort in a short space of time!!
kykayaker37- Number of posts : 139
Registration date : 2012-02-15
Re: Devimaus 69 108
NICE JOB MAN
Re: Devimaus 69 108
Space Truckin- Number of posts : 1279
Re: Devimaus 69 108
Really excited t o hear how your engine/headers run after all your hard Work
Re: Devimaus 69 108
Re: Devimaus 69 108
Re: Devimaus 69 108
Re: Devimaus 69 108
Hey,,,,,,pictures don't lie!!!!!
kayjsharp- Number of posts : 44
Registration date : 2012-04-03
- Post n°19
Re: Devimaus 69 108
Nice clicks. You rocks.
- Post n°20
Re: Devimaus 69 108
Now I will tell you the problems,,,,,He trys the bolt in the new new motor mount,,,,it gets stuck, and tears the center nut out of the rubber, some of those new motor mounts have metric threads in them,,,,,I have an extra so we keep going,,,,,there is no pilot bushing in the end of the crankshaft, so we can't put the clutch on,,,the water pump hits the timing cover and the shaft is too long on the new water pump,,,we look at my 1st Gen crossmember and put his 2nd Gen one in the same way,,,,after we put the engine and transmission in,,,,,there is a 4 inch gap between the engine and bellhousing, so we need to flip the crossmember around,,,,the trans won't go back on with the bellhousing on it,,,,needed to put bellhousing on 1st, then trans,,,,when tightening everything up other new motor mount rubber comes apart,,,,and finally,,,new front header hits the motor mount,,,,,,but it is ,,,,,,,LOOKING GOOD!
jfox- Number of posts : 111
- Post n°21
Re: Devimaus 69 108
Looking good Mau!
vanimals- Number of posts : 6
Registration date : 2012-04-23
- Post n°22
Re: Devimaus 69 108
Awesome
- Post n°23
Re: Devimaus 69 108
- Post n°24
Re: Devimaus 69 108
Awesome guys! Sounds great.
- Post n°25
