Is there any way to rebuild the mirror heads at the point where they meet the stem? (the little ball contraption.) Mine just fall every time I hit a bump, and its not so big of a deal because I have a window van, and I dont want to spend the money now since in the future I'm moving the mirrors to the top of the door. Any way to fix this?
Mirror Heads
Mirror Heads
Re: Mirror Heads
You probably need to tighten up the ball joint behind the glass,,,,,some mirrors have a screw that you can tighten next to the ball joint on the outside,,,,,if the mirror is held in by rubber, you can pop the mirror out and get to the ball joint,,,,you might be able to drill out a rivet if you can see them from the outside to tighten up the plate that squeezes the ball joint and replace it with an aluminum one to tighten it back up...
- Number of posts : 8732
Re: Mirror Heads
DONNIE IS CORRECT BUT THE 3 SCREWS RUST A BIT AND MAY NEED OILED TO REMOVE.LUBE THE GASKET TO SOFTEN UP TO GET THE MIRRIOR OUT...
DanTheVanMan- Commissioner
- Number of posts : 7900
Re: Mirror Heads
I pulled the ball out of mine and cleaned it really good sanded the ball with 80 grit to rough it up and it's been holding ever since..
