by slowflapper Wed Dec 07, 2011 8:34 am
I used a pre-cut kit for mine specifically made for A100's. The components of the kit can be purchased separately from a number of places. The insulation itself can be found at JC Whitney
(here) and at Lowes, Home Depot etc and purchased by the roll.
You can cut it to fit and then use "foil backed HVAC tape" from the places listed above to tape/seal the edges so water doesn't get behind it. Use 3M high temp spray glue or equivalent to glue the insulation to the inside of your doghouse panels (also available from the places listed above)
Quietride.com has pre-cut kits for A100's and E's as well, a link to the catalog PDF is
here I'd call them and confirm what comes in the kit.
