mo_1040
    Frenched front turn signals
    Frenched front turn signals Empty Frenched front turn signals
    Post by Guest Thu Oct 27, 2011 3:03 pm
    I want to ditch the stock front turn signals and replace the with frenched ones. I am trying to decide whether to use round or rectangle, clear or amber. I found these two that I like.
    http://www.ebay.com/itm/250918213109?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_984wt_1018
    http://www.ebay.com/itm/370505888475?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_4050wt_1145.
    Jeep has some similar round ones in clear or amber
    Frenched front turn signals Empty Re: Frenched front turn signals
    Post by Guest Thu Oct 27, 2011 4:24 pm
    mo_1040
    mo_1040
    Number of posts : 645
    Post by mo_1040 Thu Oct 27, 2011 4:30 pm
    Post by Digz Thu Oct 27, 2011 5:51 pm
    Are there any rules/laws regarding visibility for blinkers from the side? I was thinking of doing something like french but also was wondering if a person should carry it around the corner?
    Post by EconoCarl Thu Oct 27, 2011 5:56 pm
    Post by Guest Thu Oct 27, 2011 7:19 pm
    I had a similar set in Vanishing Breed. I am going with two headlights on each side so I have to rule those out
    Post by Guest Thu Oct 27, 2011 7:20 pm
    Some cars come with them sunk in from the manufacturer so I don't think that would be a problem.
    Number of posts : 1293
    Post by Lazarusvan Thu Oct 27, 2011 9:47 pm
    It seems like a lot of round up front with 4 head lights and and round signals, althought that might be offset by the rectangular/oval setup of the stock headlight bezel. I do like the visored ones the best, especially for a Frenched rear signal. My two cents..
    Post by Guest Thu Oct 27, 2011 10:16 pm
    My rear tail lights are frenched in Cadillac tail lights. The Mustang front turn signals look really nice. I think those are the ones with visors you are talking about. I was thinking the same thing about to many round lights. I am trying to get a custom oval grill made possibly out of some kind of mesh or perforated metal so rectangle lights may not look right either. Thanks for your opinion. I value it more than you know.
    Post by Guest Thu Oct 27, 2011 10:46 pm
    southern man
    southern man
    Number of posts : 486
    Post by southern man Fri Oct 28, 2011 5:46 pm
    I like those tri-bar headlights! Do they make them without the directionals (although that is a cool idea)?
    Number of posts : 575
    Post by austinmodhouse Fri Oct 28, 2011 6:10 pm
    most modern cars now have a side marker along with a turn signal (they work together but the side marker is on the side, not facing fwd)
    I’d go w/ round. for me, the big aesthetic difference between the chevy/ dodge/ford is the round rear tail lights. round just works better imho.
    if you french, I’d put a tiny single led side marker. maybe even do it flush so you wouldn’t even notice it was there till it illuminated.
      Current date/time is Sat Apr 27, 2024 10:51 am
