    Unibody metal thickness and wheelbase
    bumpbug
    Number of posts : 147
    Unibody metal thickness and wheelbase Empty Unibody metal thickness and wheelbase
    Post by bumpbug Wed Oct 19, 2011 1:56 pm
    Can anyone tell me the different unibody frame metal thickness difference through the first gen ford vans in different years, and also the wheelbase and track widths front and rear on the short wheelbase van only. Thanks.
    Unibody metal thickness and wheelbase Empty Re: Unibody metal thickness and wheelbase
    Post by Guest Wed Oct 19, 2011 7:24 pm
    90" wheel base
    bumpbug
    Post by bumpbug Wed Oct 19, 2011 7:37 pm
    Thanks Mike, I should have known that. I have heard that the thickness of the metal got thicker as the years got newer. From 61 to 64, than got thicker after that, and the heavy duty was even thicker any truth to anyof that and by how much ? Anyone know the track width front and rear ?
    Post by Guest Wed Oct 19, 2011 7:41 pm
    heavy duty meant more leaf springs, etc. No difference in the thickness of the sheet metal in heavy duty vans as far as I know. The bumpers on the later earlies were stronger as were the bumper mounts.
    Number of posts : 2198
    Post by EconoUSAparts Wed Oct 19, 2011 8:20 pm
    The frame rails were indeed thicker on the heavy duty models. I dont have any numbers on it though. I have cut up several and its very noticeable that they are thicker.
    Post by Guest Wed Oct 19, 2011 8:47 pm
    Thanks Tim, I didn't know that.
    bumpbug
    Post by bumpbug Thu Oct 20, 2011 12:04 am
    EconoUSAparts wrote:The frame rails were indeed thicker on the heavy duty models. I dont have any numbers on it though. I have cut up several and its very noticeable that they are thicker.
    Do you know if it was thicker on the standard van after 65 ? I was told that but wanted to confirm it. I was told there was 3 different thickness, 61 to 64 then 65 till the last one then the heavy duty.
    Post by EconoUSAparts Thu Oct 20, 2011 3:43 am
    I thought I heard it mentioned way back that the 61/62 models were prone to cracking around the steering box area. I *think* there may have been a change in 63 but not sure. I personally have never run across the cracking issue on any of mine.
    Number of posts : 1747
    Post by econopoor Thu Oct 20, 2011 5:54 am
    Pickups have thicker outter sheet metal in the rockers than vans did. Vans had the interior ribs for added support where pickups didn't. All Supervans have the thicker frame like the heavy duty trucks. I don't have the numbers from the various pieces but I can get them. I have cut up many and still have sections from all of them. What exactally are you looking for?? I'd be happy the measure any part needed.
    bumpbug
    Post by bumpbug Thu Oct 20, 2011 9:27 am
    econopoor wrote:Pickups have thicker outter sheet metal in the rockers than vans did. Vans had the interior ribs for added support where pickups didn't. All Supervans have the thicker frame like the heavy duty trucks. I don't have the numbers from the various pieces but I can get them. I have cut up many and still have sections from all of them. What exactally are you looking for?? I'd be happy the measure any part needed.
    I would like to know if the frame part thickness of the uni-bodies changed through out the years. were they made stronger where the leaf springs and things attach, the whole frame or what. I want to maybe make a 4X4 out of one and want to start with the best thickness I can find, or are they all the same and I just need to beef up parts. Is the heavy duty a lot thicker or just barely that it wouldn't make much of a difference.
    Post by EconoUSAparts Thu Oct 20, 2011 4:56 pm
    Get a Heavy Duty to start with if possible. The front spring perches are larger and beefier on all Econos 65 and up. Possibly even on a 64 but I would have to look at mine in daylight to see.
    Post by econopoor Thu Oct 20, 2011 5:28 pm
    I'll look at some of the frame sections I have here and see what the differences are this weekend. Like Tim said. A 65-67 Heavyduty would be the way to go. 61-62's were the weakest by far. I've also seen several 63's with frame damage. I don't know why I see more 63's with damage than the others but I do. I just finished cutting up a 64 Heavyduty so I can check that in comparison. It will be interesting to see the differences.
    bumpbug
    Post by bumpbug Thu Oct 20, 2011 6:16 pm
    Thanks for the reply's If you guy's get a chance to post the info I would appreciate it, Where did you see the cracks at when you saw them ? Thanks
    bumpbug
    Post by bumpbug Sat Oct 22, 2011 8:31 pm
    Anyone get a chance to check thickness on pre 65 post 65 and heavy duty ?
    Post by econopoor Sun Oct 23, 2011 11:29 am
    I checked the ones I had around here today. I was very suprized at what I found. The 64 heavy duty, 65 heavy duty, and the 67 supervan all measured about .120 in the main frame rail. The 62 pickup I cut up measured .050 in the same place. That's a really big difference. It really makes me rethink building the 61 pickup I have. I may go back to finding a 65-67 to build. I had no idea the earlies were that thin.
    bumpbug
    Post by bumpbug Sun Oct 23, 2011 2:46 pm
    econopoor wrote:I checked the ones I had around here today. I was very suprized at what I found. The 64 heavy duty, 65 heavy duty, and the 67 supervan all measured about .120 in the main frame rail. The 62 pickup I cut up measured .050 in the same place. That's a really big difference. It really makes me rethink building the 61 pickup I have. I may go back to finding a 65-67 to build. I had no idea the earlies were that thin.
    Thanks for that, any idea on what just the non heavy duty frames would be on the vans.
    Post by econopoor Sun Oct 23, 2011 6:23 pm
    The only non-heavy I have is a 67 pickup. It's still intact so I'll have to see if I can get a measurement of the frame. My 67 eight door is not a heavy duty but I believe the eight doors had a heavy duty frame as well. I'm pretty sure I heard that sometime ago. I'll check my 67 pu and let you know.
    Duane in Tennessee.
      Current date/time is Sun May 19, 2024 2:45 pm
