Starter is out on the Hoopty.. Bought a replacement at Carquest and its not even close to being the right one. Anyone have a valid number for one at AutoZone, Advanced Auto, Carquest etc??
225 Slant/Manual 3 spd. Starter Question
Dantra- Number of posts : 293
Napa= part #= ray 241083 or better one - napa # ray=441083 remember napa has the parts & Experience @ the counter=usually
Nearest Napa is 20 miles...
Thanks for the info
Thanks for the info
Autozone shows a 3250 or a DL3250 as the replacement. It looks correct according to the image but you never know.
Oreilly is showing a Bestest starter that also looks right, pn 03-0213X. They have an Ultima line, same part number minus the x (03-0213).
The NAPA numbers twinpilot gave were for automatic, I'm sure its the same starter but the manual trans pns are; RAY 441055 for the power supreme line, RAY 2441055D for the Delco style premium line and RAY 2441055 for non-Delco style in the premium line.
Any of these should bolt right up and work like a charm for you.
A small block 273-360 starter will fit also.
benwah wrote:A small block 273-360 starter will fit also.
Not only that, this same starter will fit pretty much any Chrysler engine in the 60's and 70's to include; 170, 198, 225, 273, 318, 360, 383, 400, 426 Hemi, and the 440. About the only exception are the industrial/large truck engines like the 413 and others not found in cars/light trucks/vans.
Last edited by MoparFreak69 on Tue Aug 23, 2011 4:45 pm; edited 1 time in total (Reason for editing : Added some info.)
Thanks for the answers.
