    overhead console
    Number of posts: 299
    Registration date: 2009-02-02
    overhead console
    Post by bugeye bob on Wed Aug 17, 2011 5:41 pm
    does anyone know of a manufacture of the overhead console that goes all the way across the headliner behind the windshield, ithink back in the 70's they were made out of plastic and you could mount your radio and cb in them along with switches. i really don't want to cut a hole in my dash.
    BajaCharlie
    Number of posts: 589
    Registration date: 2010-01-07
    Re: overhead console
    Post by BajaCharlie on Wed Aug 17, 2011 5:44 pm
    I've seen dozens in the yards but I never one for an early.
    Number of posts: 635
    Registration date: 2010-07-29
    Post by slowflapper on Thu Aug 18, 2011 7:44 am
    I don't know of anyone that makes one but you could probably fabricate something pretty easily. I plan on doing one myself with tin "hat channel" framing studs from home depot and 1/4 plywood (cover it with thin speaker carpet).
    Number of posts: 22729
    Registration date: 2008-05-06
    Post by G-Man on Thu Aug 18, 2011 11:39 am
    I also never seen a aftermarket overhead for a early, only 3rd gen chevy's 2nd gen ford and 2nd gen dodges and up
    Number of posts: 6814
    Registration date: 2008-10-08
    Post by DanTheVanMan on Thu Aug 18, 2011 12:24 pm
    Thinking you could make this one fit...
    http://cgi.ebay.com/ebaymotors/Overhead-Storage-Shelf-98-06-Ford-Econoline-Van-Tan-/330556894810?pt=Motors_Car_Truck_Parts_Accessories&hash=item4cf6b9ee5a
    1999 Cadillac Eldorado
    1999 Buell S3 Thunderbolt & 2007 Buell XB12 Lightning
    Post by G-Man on Thu Aug 18, 2011 12:28 pm
    I had one of those on my 3rd gen chevy work van, it's for the most part a shelf, but holds alot of stuff
    Number of posts: 1461
    Registration date: 2008-05-29
    Post by dix on Thu Aug 18, 2011 6:04 pm
    I would not expect to find a early over-head console manufacture. I went to home depo and used 3/4 x 3/4 alluminum angle, measured left to right cutting the front side to lenth and the botton 1 1/2 inches longer each side. and bent that up and screwed it into the inside gutter. then used a firing strip tuck it in to the gutter arch it up toward the roof and tuck it into the outher side gutter. then it's 1/9 in laun plywood. If you go to interior and look up overhead console you should be able to see most of this...
      Current date/time is Wed May 16, 2012 2:22 pm
