Guys, ive heard a lot of good things about Champion radiators. Just took a look at their website and nothing specifies a Ford Econoline Van. Those of you who use them which did you purchase? The one listed for a falcon specifies a 289motor. Im wanting a 3 core rad.
Radiator And Shroud
Rayallen- Number of posts : 648
Radiator And Shroud
Re: Radiator And Shroud
sent a pm to a member, should get my question answered soon.
http://cgi.ebay.com/ebaymotors/3-Row-Aluminum-Radiator-Ford-Mustang-1965-1966-CC251-_W0QQcmdZViewItemQQhashZitem2310399540QQitemZ150596064576QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
I don't know what size motor you have but this is the right length and width. I used one like it but mine is a four core which will cool better than the three core.
I will look into the 4core to. Now I know the size I need. AS far as my motor its the 200ci.
I have a 200 in my 65 with the four core Champion and it never gets hot not even in 118 degree weather.
probably going to go with this one. Even says 1964 ford econoline in the list of vehicles it matches.
http://cgi.ebay.com/ebaymotors/1960-1965-Ford-Falcon-4-Row-Aluminum-Radiator-Fan-_W0QQcmdZViewItemQQhashZitem1c1e18a762QQitemZ120764016482QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories#ht_11100wt_1244
You will need to use longer bolts and some spacers to get it to work. That is what I have in my 200. I hope that is a high CFM fan like 2800 or higher.
LVMtnMan- Number of posts : 30
Registration date : 2013-05-05
what do you guys think about a champion 3 core with a 2500cfm e fan in a 170 in the desert heat?
should do the job 4 ya =shroud also????????????? vegas gets really HOT!!
agood1 wrote:Did any of these ebay radiators work?
Champion is the way to go. I've honestly not put me 3row rad through a true test yet, but talk to a few van guys and you will see Champion preferred time and time again.
I bought the 3 row, but you could get the 4 for a bit more money.
