    Power windows installed in early vans, using original hand crank handles
    Number of posts : 1686
    Power windows installed in early vans, using original hand crank handles Empty Power windows installed in early vans, using original hand crank handles
    Post by westcoastvanner Mon Nov 17, 2008 8:18 pm
    Check out this web site, they provide interesting power window ideas.
    http://www.thehoffmangroup.com/autoloc/product.lasso?prodinc=electricwindowcrank
    Power windows installed in early vans, using original hand crank handles Empty Re: Power windows installed in early vans, using original hand crank handles
    Post by donivan65 Mon Nov 17, 2008 11:18 pm
    This is just a fancy switch,,,,,,finding a motor and lifting mechanism that can fit inside our small doors is the real obstacle,,,,,
    Number of posts : 7900
    Post by DanTheVanMan Tue Nov 18, 2008 6:02 am
    Power windows installed in early vans, using original hand crank handles Qr_cod10
    Number of posts : 946
    Post by BvrWally Tue Nov 18, 2008 6:07 am
    Today there are plenty of after market companies that produce something that would fit OK. Street Rodders have been using them for a number of years now. I searched High & Low for something to work in mine, as I too wanted Power Windows! I ended up using the mechanism from a 78 Cadillac "Rear" actuator combined with my arms. Fit inside the door nicely. Just a thought?
    B.W. Smile
    Post by donivan65 Tue Nov 18, 2008 8:44 am
    We installed the JC Whitney one in a 2nd Gen Chevy, but after a while we got tired of that big bump on the door panel. Then we tried a hot rod one but it was too long to fit under the glass. but a Plymouth Voyager one was just right,,,,,,,
    wacko
    wacko
    Number of posts : 423
    Post by wacko Tue Nov 18, 2008 9:30 am
    I found this how-to on youtube very helpful for this problem, fairly inexpensive as well.
    https://www.youtube.com/watch?v=GLsyM2Crhew
    Post by DanTheVanMan Tue Nov 18, 2008 9:46 am
    wacko wrote:I found this how-to on youtube very helpful for this problem, fairly inexpensive as well.
    Well then. Problem solved!!!!! Can't stop laughing.... Thanks Wacko...
    Post by BvrWally Tue Nov 18, 2008 1:59 pm
    There you go!!!! All you got to do here is "Ask!" ROTFLMFAO!!!!! Smile
    B.W.
    Post by G-Man Tue Nov 18, 2008 5:00 pm
    Red Green can fix anything
      Current date/time is Thu May 16, 2024 6:49 pm
