Will the stock 67 display van or falcon side pop out windows fit into the back door window slots of the 61 to 64 van. Can they be interchanged if the back doors have the stock non opening windows by rotating them? Thanks for any help.
Pop out side windows
bumpbug- Number of posts : 147
Re: Pop out side windows
Yes they will. Any pop out will fit any door or fixed window position regardless of year.
Thanks for the reply. . . . are they hard to come by or are there still plenty floating around if you wanted one. I guess in other words are they worth grabbing from a junk yard if you run across them that they are getting hard to find.
The frames tend to rust so good ones are hard to come by.
Have a 65 econo cargo ... running pop outs in the rear doors ... PTL ... on hot days ... nobody coming up with the seals except Tim in KY ... he dropped off an entire van for repro ... nobody else went that far that I know of ... cross your fingers ... might come to something
J=M BC
J=M BC
