Hey folks, it will be a few days before I get the chance to really try and work this out so I thought Id ask for some advice here in the meantime.
My lovely wife took the van to the store yesterday and told me when she started it up to come home it wouldn't idle (it would just drop right off and quit). I checked it when she got home and that was indeed the case, you had to stay feathering the gas pedal to keep it running.
I turned the idle screw up probably a full turn to keep it idling and then checked the timing, it "appeared" to be a good 5 degrees off so I set it back to 5btdc. Note that the scorch marks inside the distrib cap appeared to be right where they should be though so whatever happened occurred on this run to the grocery. It's idling ok now but it will occasionally backfire through the carb when you rev it up (which I know is a definite sign of something gone awry).
The last major change I made was several months ago when I put on an OEM re-manufactured carb (OEM carter BBD) and a new distributor, been running great since then. This weekend I plan on going through the motions of a tuneup first thing, resetting the timing and idle, checking points etc. If I don't sort it out that way I have my original carter BBD already rebuilt and waiting on the shelf, I plan on swapping carb (a 20 minute job) to rule out any carb related issues. If the carb swap doesnt fix it I know it's in the ignition somewhere.
Anyone got any quick idea's as to what might have gone wrong to cause the idle to drop so far so quickly?
