clutch actuation seems a little stiff - looking at the mech i spot poss 2 problems - 1 is the long rod from the pedal assm to the next assm , supposed to be a long piece of threaded rod - like all thread - i am thinking this may flex some or ? - 2 the assm that is next _ dont know what to call this - transfers the action from the long rod to the clutch assm itself - has a tube assm with maybe bearings or bushings and a grease nipple - i think there is some play in this - cant find any info in my fsm -this is where a factory parts manual would be handy - are there any parts available for this - at some point i will disassemble but can someone tip me to what is in this assm - oo3
clutch assm parts?
oo3- Number of posts : 290
clutch assm parts?
Re: clutch assm parts?
Clutch Cross shaft - the mechanism that goes between thye adjustment rod and actual clutch fork(into bellhousing) check for mis alignment or bad engine mounts-puts bind on the cross shaft if bad. The cross shaft will need greasing- should be possibly some zerk grease fittings possibly there . Check all mounts including tranny. Loose bellhousing bolts also can be a problem. The actual clutch rod - should never be looking like all-thread- should have possibly threaded ends or at least 1 threaded end - if all thread is used it is never strong enough to carry the presser.
I think it's covered in these... if not, the are still fun to watch!
Dodge Technical Service Bulletin
https://www.youtube.com/watch?v=kcewnrO5vIc&feature=related
https://www.youtube.com/watch?v=F3J-KeyDRZU&feature=related
those youtube tsbs were very good - but did not cover for this post - did get a confirmation from brian bowie - the all thread rod is wrong - there is supposed to be a straight rod with 90s at each end with cotter pin - no adjust on rod - adjust is on clutch actuating arm - the cross shaft they are calling a z bar - there are nylon bushings in there - possible parts thru year one - thanks to all - oo3
» Trailer & tow bar assm.
» Parts,parts,& more parts=dodge, econo & chev stuff
» Sheet metal parts This buisness sells many different metal replacement parts for older cars trucks!! I know i have seen some van parts for our vans here from him!1 If it isnt listed - email or call them!!
» newbie, parts and parts pics and part locations
» Brake light switch
