+10
fmc56
14 posters
matt's first
matt's first
so i dove right in and started the process and never thought it would be this much fun. my wife is getting nervous that she won't be able to fit her car in the garage this winter since i have completely taken it over. i converted the front brakes to discs using the D&D brackets. they worked great, very easy to follow directions on they're site. learned how to bend brake lines and flare the ends and replaced all the old lines. converted the master cylinder two a dual using the modern form bracket, a little expensive but seem to work great. just sent out the bumpers to get chromed. and i'm in the middle of dismantling the dog house to clean and insulate. of course i realized that i had to take the battery box out and then realized i'd have to take the front seat out which is fine they could use a cleaning as well. also taking apart the front windows so i can get the vent window frames chromed. i have some questions on engine stuff but will post those in the econoline discussion.
Re: matt's first
They looks great!!!
Re: matt's first
Looks awesome Matt. Kinda stinks though that you have to buy that expensive master cylinder kit. Not sure why Ford just didn't adapt an existing dual circuit master to work on the Econolines.
Re: matt's first
thanks guys
i know that would have been nice. i asked dennis from D&D brakes if he had a rear disc brake conversion, he said no but it was because he was working hard on a master cylinder bracket. i believe he said it would be a quite a bit cheaper and he seems to do good work. so maybe that will be available soon.
Re: matt's first
Does the van have a 9" rear? They gotta make kits for that. I know Mike Cook's "Vanishing Breed" has rear disc brakes.
Re: matt's first
it doesnt but i am replacing my axle with a 9" soon. who do you think would have that kit
Re: matt's first
Looks great Matt! My guess is that rear disc brake conversions are more generic than these fronts, as most newer vehicles have disc /drum combos, and the drums get updated. Looks like you could simply adjust your proportioning valve to get the right pressure to front and rear when you do that upgrade.
And good for you buying the wilwood mc... at least you're starting with new and very compact hardware! I want to go that direction rather than with a 67 rebuild.
jkr- Number of posts : 1148
Re: matt's first
the rear axle from the granada/lincoln cars should be almost a perfect fit for an early fordvan or pickup. they were the hard to find but had rear discs. the other good ford one was the thunderbird super coupe turbo cars with rear discs. they were the 8.8 if memory serves me correct and i'm a dodge guy so go easy on me.those turbo rear diffs were as hard to destroy as a 8 3/4 dodge and easier to find.
Re: matt's first
thanks guys
i'll tell you both conversions were really easy even with somebody with my knowledge or lack of. good idea jkr. i was planning on getting a 9 inch from a salvage yard. i wonder if going your route would be better?
fmc56- Number of posts : 553
Re: matt's first
The Granada axle is too narrow. Ford Explorer rear discs will fit the stock Econoline 9" rear axle. They are hard to find but Henry's Auto Parts had two last time I was there. They are simple to remove. Just remove the rear cover from the center section, push out the lock pins then slide the axles out and remove the caliper brackets. New rotors and calipers are relatively cheap. The emergency brake is a small drum brake that fits inside the rotor and is engaged by a cable. There are also several aftermarket kits available.
Fred
Fred
Re: matt's first
hi guys
here is the parts van i got on ebay. its got a mustang 289 v8 which i plan on rebuilding(any input on rebuilds would be great). it has a 9" rear axle so i will be able to throw those explorer discs on there(thanks fred). new heater. lots of good stuff to use or store for an emergency. so would anybody have use for a 170 engine that runs and drivetrain with 8" rearend or should i junk them?
Re: matt's first
It's always great to have extra parts. Good score
Re: matt's first
hang onto that breather and steering wheel. the breather will sell for a good buck to some ford restoration person. looks mid to late 60's and an oil bath type to boot. the horn ring on the steering wheel will look good in your own van. after you get what you need take the rest and park it down behind the horse in the field cause old parts are hard to find and running out.
the wheels on the yellow van possibly a dodge or chrysler part???
Re: matt's first
thanks gman. what is a breather exactly? still learning. i am definitely going to strip it and save what i can and sell what i can.
wideload- Moderator 1st Class
- Number of posts : 1388
Re: matt's first
Mattvinc the breather their talking about is the air cleaner on the motor. Instead of having a removable filter, it filters the air through a small amount of oil that is inside the aircleaner. wideload
Re: matt's first
jkr's right save everything you can or have room for. Last summers high scrap prices hurt us a little. I don't see near what I did on ebay for parts. The parts I saved from my van I traded or sold to other vanners. Many small items I just gave away to help guy's out. Last summer I sold some maniflods to KC. He is restoring his 69 to stock. I now have headers, but these manifolds were in very good condition I saved and moved these things around 20 times at least. Helping another vanner is alway a good feeling with a much needed part.
Re: matt's first
cool thanks wideload. do you guys think anybody has use for a 170 engine and drivetrain(8" rear axle)
- Post n°19
Re: matt's first
Matt anything that is a factory stock item and still useable is worth saving if you've got room to store it. A lot of this stuff is getting really hard to find and a lot of guy's like to put these old vans back to orginal apperance. Like G-man said, it gives you a good feeling to help out a fellow vanner looking for parts and who knows next time it might be you who needs a part. wideload
- Post n°20
Re: matt's first
- Post n°21
Re: matt's first
