    Fuel filler problems on A100
    Number of posts : 745
    Fuel filler problems on A100 Empty Fuel filler problems on A100
    Post by kiwimopar Mon Apr 18, 2011 3:04 pm
    Hi guys,
    I recently filled my gas tank for the first time Rolling Eyes and took it to my upholsterer to fit a headliner. He called me the next day to say the fuel was spewing out the filler. Now the tank was about 3/4 full, and there is a breather pipe. The sun was hittng the rear end, and warming the bodywork nicely. I have also fitted a 69 Charger flip-cap, so it does not breathe. I wondered if anyone else had similar problem with a tank pressurising like this. Even after venting (popping the cap) a few minutes later it was pushing fuel out the filler neck. I had to drain the tank as much as possible to prevent further fuel loss. I checked my breather tube and noticed the vent tube for this is at the bottom of the filler neck (six o'clock position near the cap) as opposed to the top (12 o'clock position). And there was a small amount of fuel in the breather tubing.
    I will post pictures as soon as I can get the truck home. Looking forward to any pearls of wisdom from other owners Wink
    Fuel filler problems on A100 Empty Re: Fuel filler problems on A100
    Post by Twinpilot001 Mon Apr 18, 2011 4:12 pm
    must breathe/vented type i do believe on the older models
    leave the cap loose till u can replace it.
    Number of posts : 8732
    Post by dix Mon Apr 18, 2011 6:44 pm
    yes the vent should be @ 6:00 I agree with twin pilot she has to breath.is the flip cap the onlt cap you have on it or is there a 2nd cap on there if the flip cap is the only cap you have then either take off some spring puessure off or drill a few small holes thru the rubber that is sealing it off so tight.also make sure the breather tube is open . near the leaf springs threr is a 90 degree turn in the rubber that may have colapsed. that is my guess. when the gas expanded it filled the vent tube. you said the gas is still there . that makes me think it is cloged, or colapsed..
    Number of posts : 956
    Post by slowflapper Tue Apr 19, 2011 6:47 am
    If the sun is shining on the back of my van for a bit I can smell gas fumes coming out of the tank. I have a locking gas cap but it is loose enough to have about an 1/8th or 1/16th of space between the filler neck and the rubber gasket on the cap (just enough to let pressure out).
    My tank has an overflow/vapor vent line that runs off the top of the tank and goes up into the body work where the tank filler line is, I assume it hooks back into the tank filler line up there somewhere. Also, when adding fuel I only fill it until the gauge says full, I don't "top it off" to prevent an overflow like you experienced.
    I haven't had mine overflow like yours did though, you definitely need a vented cap and don't make any sparks around it when the sun it out Smile
    Post by Guest Thu Apr 21, 2011 9:38 am
    I have the same problem as welll. From what I've learned is that there is no venting for these, the cap is supposed to be vented which mine is and still l have this problem. I have found that I can only fill it half fulll, anything more and I have a problem with it pissing out the filler neck. As much as I hate it, it's something I have to live with until I can come up with a solution to prevent this from happening.
    Post by slowflapper Thu Apr 21, 2011 1:09 pm
    Something else Id like to add just as food for thought for you guys with the overflow problem.
    Like dix mentioned, is there a chance your overflow tubes are collapsed or plugged with something? It should vent vapor out of the top (drivers side) of the tank with a 3/4" rubber hose.
      Current date/time is Sun May 19, 2024 12:52 pm
