    Slave Cylinder? Need Help.
    Number of posts : 864
    Slave Cylinder? Need Help. Empty Slave Cylinder? Need Help.
    Post by Casimier Sun Mar 27, 2011 5:45 pm
    Need some info on a slave cylinder.
    Got a 66 pickup. I was changing the brake lines back on top of the rear axle at the union for the lines.
    Well, one line comes from the front, two lines go out to each wheel.
    So, I notice on top of the slave cylinder, or union is a flex line..going vertical.
    I follow it up towards the gass filler it gets buried in sheet metal.
    The concern is that the hose is broken and where it attached to the top of the slave,
    inside the hole is all dirt.
    What do I do?
    Slave Cylinder? Need Help. Empty Re: Slave Cylinder? Need Help.
    Post by Digz Sun Mar 27, 2011 6:03 pm
    Im no ford guy , but you have me wondering if they are using rear axle vent as an anchor for the brakeline union??
    Post by EconoCarl Sun Mar 27, 2011 6:25 pm
    Jim, the bolt holding the union is hollow and it does vent the rear end. It has nothing to do with the brakes, other than holding the brake line to the rear end.
    Number of posts : 2198
    Post by EconoUSAparts Sun Mar 27, 2011 7:30 pm
    Slave cylinder????? Where you seeing one of those at?
    Post by Casimier Mon Mar 28, 2011 3:39 am
    hey guys thanks for the info...
    With all the vans I've had, I never had the opportunity to run new brake lines.
    Hence, slave cylinder=axle vent..Smile
    Post by EconoUSAparts Mon Mar 28, 2011 8:00 am
    Im used to a slave cylinder on a clutch on newer cars but not on these old boxes.
    Number of posts : 2067
    Post by sasktrini Mon Mar 28, 2011 12:19 pm
    You aren't talking about the fuel tank vent line, are you? There would be a long u-shaped tube that loops up and down through the floor, rubber hose running to the top of the fuel tank.
    Post by Guest Tue Apr 05, 2011 6:06 pm
    Corey I looked at the 66 Shop manual I have. It shows the hose your talking about goes to a hollow bolt that goes through into the axle housing for venting. It works a double job of venting the axle housing and holding the brake line T body to the housing.
    Your 66 E van they must of put a rubber hose on it to vent up in the gas filler box. They may of been afraind it would plug with dirt just sitting on top of the axle. It has nothing to do with brake fluid in it.
    If there is brake fluid. You would be pumping it out pretty fast.
      Current date/time is Tue May 07, 2024 4:05 pm
