    Handle Pad Material
    Spank
    Spank
    Number of posts : 60
    Registration date : 2010-04-15
    Handle Pad Material Empty Handle Pad Material
    Post by Spank Mon Mar 21, 2011 10:11 am
    Are there handle pads on the rear doors? If so are they available or is sheet material available? Macs only has the front set. The rears sure look like they could use something similar.
    Number of posts : 2198
    Handle Pad Material Empty Re: Handle Pad Material
    Post by EconoUSAparts Tue Mar 29, 2011 6:48 pm
    Handle pads???? Are you referring to the black plastic/rubber thingys that go on before the handle? And if so,the cargo doors didnt have any of those.
    southern man
    southern man
    Number of posts : 486
    Post by southern man Wed Mar 30, 2011 1:06 pm
    Is there a source for the front black plastic trim pieces that go between the door and the handle (like what I think Tim is referring to)? I have one but need another.
    Spank
    Spank
    Post by Spank Wed Mar 30, 2011 3:21 pm
    Macs has the fronts. I believe they are hard plastic.
    I didn't like my freshly chromed bezels on the rear doors touching the fresh paint so I looked around the home depot for an hour for some material that i thought would work. Ended up getting some black closed cell foam marketed for drawer lining. Cut it to size. Nicely padded.
    Post by EconoUSAparts Wed Mar 30, 2011 6:46 pm
    Ok,I thought you were referring to the interior door handles but now I see you mean the "gasket" piece between the exterior handle and the body. I know the fronts have em but I havent found any on the side or rears while disassembling them so Im guessing no.
      Current date/time is Fri May 17, 2024 11:29 pm
