Does anyone on here own a 61 Econoline Station Bus or a 62 Falcon van? I need some pics of the rear seat floor brackets configuration.
61/62 window van owners
Re: 61/62 window van owners
golas wrote:61 ECONLINE REAR SEAT BRACKETS
Im not following you. Are you asking for the seat straps or saying you have pics of the floor brackets in a 61?
Ok,those are the straps that bolt to the floor brackets. What I really need to see is a picture of the frontmost bench seat floor bracket configuration. Thats the brackets that are welded to the floor. I need to see a pic that shows all the brackets as a group so I can see the spacing. This is just for the front bench seat. The rear position bench seat floor brackets are all the same. The fronts however changed a few times over the years. A full set of straps woud be 4 small straps for the rear seat and 2 small and 2 large for the front position seat. So far I cant find any reason the large straps are even needed. All 63 thru 67 front bench seats will install using 4 small brackets just like the rear one. The key to the large straps has got to be with a 61 or 62 model.
Also a 63 would have 2 additional small straps on the front seat just for the armrest that bolted to the floor. That was eliminated in late 63 or 64 when the armrest bolted to the seat underside instead.
Tomorrow Ill shoot ya some pics of all the floor bracket and were they lay.They seem to be all the same. hope that'll help.
g
g
Thanks, I ve been trying to solve this mystery for years. Im in the process of having new straps and t-bolts made up and so far see no reason to make the large straps.
elmonto- Number of posts : 56
Registration date : 2010-07-09
My 62 falcon wagon has the stock rear back seat and it just bolts down with some rounded steel pieces. Id take a pic but i took the seat out last week
Welcome to the site golas!!!!!
elmonto wrote:My 62 falcon wagon has the stock rear back seat and it just bolts down with some rounded steel pieces. Id take a pic but i took the seat out last week
Even better that the seat is out cuz what I want to see is the floor brackets the seat bolts to. I need a pic of where the rear bench mounts in the front position,closeest to the doghouse. Some vans had to rear seats and had another by the rear wheel wells but those are all the same back there. can you get me a pic of the front position floor brackets taken as a group shot in one picture,or at least break it down by sides? It would be much appreciated. Also is yours a Deluxe model? A base model normally wont have rear seats unless special ordered that way so the brackets could be different in that case.
By the way,the round steel pieces you speak of are what Im in the process of reproducing along with the t-bolts. Scroll up in this thread and you will see a link from Golas to a pic of them.
fmc56- Number of posts : 553
Tim,
Contact Doug Shinn, he has a 62 DCW he is working on.
Fred
Fred
Fred do you have his email address?
I took the carpet up and it looks like my seat isnt og. There are just holes drilled in the floor haha sorry cant help.
tim
took some shots yesterday and posted them here
hope this helps
http://gallery.me.com/goliva#100869
hope this helps
