how can i find out the gear ratio on my 8 3/4. idk if the stamping on it tells me? help me out guys!
rear end info
Re: rear end info
It will be stamped on the info plate beside the drivers seat (on the wheel hump). There may also be a metal tab under one of the nuts holding the chunk into the rear housing that has the ration stamped on it. Last resort is that its stamped on the edge of the ring gear.
moparhead340- Number of posts : 85
Registration date : 2010-12-01
Re: rear end info
so it will say if its like a 3.91 or a 4.10?
jkr- Number of posts : 1148
Re: rear end info
if it's out count the number of teeth on the pinion and ring gear. divide the ring gear into the pinion.
Re: rear end info
moparhead340 wrote:so it will say if its like a 3.91 or a 4.10?
Yep, mine was a 3.55 for example and had 3.55 stamped on the ID plate inside the drivers door (on the wheel hump).
Here's a good bit of info on rear ends.
Gear ratios available on the 8-3/4" axle through the years include:
2.76, 2.93, 3.23, 3.31, 3.55, 3.73, 3.91, 4.10, 4.56, 4.89, 5.17, 5.57.
Re: rear end info
sweet thanks guys
