I'm going to stripping my van out and while I have the motor and tranny out, I'd like to put a new wiring harness in. What have you Ford guys used? I'm looking at the Painless 66-73 Bronco Chassis harness.
Wiring harness help
StuNami- Number of posts : 437
Registration date : 2010-12-14
Wiring harness help
Re: Wiring harness help
eric67vanpkup- Number of posts : 85
Registration date : 2010-12-07
Wiring harness help
I am using a mini fuse setup from a company called Ez Wiring.
http://www.ezwiring.com/wiring_harness.html
Eric
Eric
organ grinder- Number of posts : 149
There was a thread on this a couple months ago but I can't seem to find it, must be that old age they all keep talking about. I would talk to Southern Man and get his input as he is wiring his van now. I think he is using a Ron Francis kit
I have used both the Painless and E-Z wiring kits plus the Ron Francis. When the time comes to do my P/U I'm going to use the Ron Francis. You have to put them side by side to see the real difference in quality between them. Good luck with it, whatever kit you go with.
So are the EZ wire basically univerisal and have everything that an econo has stock? I'm digging the 18 fuse 21 circuit and I'm sure the stock harness can't handle the 200 watt amp and other goodies I want to install.
Never mind. I found this on another site.
The EZ 21 includes all the basics plus all major accessories:
A/C
Power Windows
Horn Relay and Connector
Turn and Hazard Signals
Dimmer Switch Connector
Wires Included in Harness: Power Door locks
Electric Fuel Pump
Circuit Breaker for Headlights
2 Flashers
Backup Lights
1 Alternator Plug
Alternator exciter wire
2 Ignition Switch Connectors
Plus more
Black or Color-Coded
Horn
Cigarette Lighter
Power Window
Power Door
Accessories
Cruise
Fan - Engine
Fuel Pump
Dome Light
Trunk Light
Heat/Air
Choke
Instruments
Radio Battery
Radio Acc
Wipers
Turn Signals
Park Lights
Hazards
Turn Flasher
Brake Lights
Coil
Tachometer Leads
Instrument - Harness
Headlight Connectors
Alternator Connectors
3rd Brake Wire
GM Column Connectors
Headlights
Back up Lights
Tail Lights
A/C
Power Windows
Electric Fuel Pump
2 Flashers
Backup Lights
1 Alternator Plug
Plus more
Horn
Cigarette Lighter
Power Window
Power Door
Accessories
Cruise
Fan - Engine
Fuel Pump
Dome Light
Trunk Light
Heat/Air
Choke
Instruments
Radio Battery
Radio Acc
Wipers
Turn Signals
Park Lights
Hazards
Turn Flasher
Brake Lights
Coil
Tachometer Leads
3rd Brake Wire
Headlights
Back up Lights
Tail Lights
