im looking for the little module that replaces points in my distributor. can anyone recommend one? the parts store retards dont know what im talking about.
elmonto
i hate points!
elmonto- Number of posts : 56
Registration date : 2010-07-09
i hate points!
Re: i hate points!
ebay - there many
Re: i hate points!
I would go with a Mallory Unilite distributor. Better performance etc.
Re: i hate points!
if just looking for a points conversion pertronix is what you are looking for, use your stock dizzy and retain original look. I've had good luck w/ them.
http://www.pertronix.com/
Old Skool- Econoline Guru
- Number of posts : 1306
Re: i hate points!
Also the Ford Dura Spark,, some prefer the Ford module that uses a white wire to retard the spark for easier starting and still get full advance curve also at the same time, some prefer the GM module and lastly the Dodge module. Only thing to consider is the size of your hex on your oil pump. Earlier and smaller motors will have the 1/4 drive, later uses a 5/16th drive. The smaller early block CAN be drilled out to use it, but suggest only doing that if you have and also when rebuilding it. Here is a link on the Dura Sprk for you to read anyways.
Vic
http://www.mustangsteve.com/conversion.html
Vic
score602- Number of posts : 140
Registration date : 2010-04-05
Re: i hate points!
i have a distrib out of my 170 with petronix in it if your interested...kit is less then 3 months old and i probly drove it a total of 200 miles
Re: i hate points!
After all of the posts, I still haven't read what size motor you have?? There is a DUI for the big six also, but have heard rumor it hits the doghouse. The Pertronix is well tested and seems to work very well, but I am not familiar if its available for the big six?? the Dura Spark for either the big six or the small six as mentioned.
vic
vic
Re: i hate points!
the pertronix drops into your current distributor. it is nearly universal and I'd be surprised if they did not have one that fit just about any traditional distributor.
Re: i hate points!
i have a 170 with a 200 head btw. i just ordered a new stock distributor, since mine was the factory og with the oil flap. next is the pertronix module. 3 or 400 bucks for one of those fancy distributors is ludacris.
Re: i hate points!
u will love the conversion
Vanner63- Number of posts : 235
Re: i hate points!
Mac's Econoline parts sells the Pertronix conversion. I think its about 80.00.
