I am trying to help my dad out again with his Ford. He relayed all of this information to me over the phone so I hope I get this correct enough for someone's advice.
How can you tell if the advance mechanism is not working? The van seems to have a vacuum problem, it doesn't run well when cold and then runs better once warm. When it was warm, it seemed to run much better under higher RPM. Also, pulling any of the plug wires off at anytime didn't make it run worse than it already did. It misses like crazy.
Now that it is so cold in Indiana the van won't fire and run at all. It backfires through the carb and seems to be out of time. The advance mechanism in the distributor seems to be completely stiff and won't move when pushed or rotated.
What should we look for or test? The diaphragm is fairly new. Thank you in advance for your help.
