I have a 1966 G10 van and I am redoing the gas tank.. And i am in the market to get a new grommet for the neck filler.. Anyone know where I can get one?
Gas Filler Neck Grommet
1966G10- Number of posts : 138
Registration date : 2009-10-14
Re: Gas Filler Neck Grommet
,,,,,and where is this grommet? The filler neck bolts onto the body and then a 9" hose connects it to the tank,,,,,,,,
sparky- Number of posts : 195
do you suggest the napa 1 1/2 " fuel filler hose or is the slightly smaller inner diameter stock size available somewhere ? is a stock one available at the dealer ?donivan65 wrote:,,,,,and where is this grommet? The filler neck bolts onto the body and then a 9" hose connects it to the tank,,,,,,,,
The real stuff is 1 3/8",,,,,,,,,,,,that Napa 1 1/2" squashes down OK,,,,,,I see people finding 1 3/8" hose but it is for coolant,,,,,,,,MountainKowboy was selling hunks off a long piece he bought,,,,,,,,
Thanx Don, I think you can go in to the ford dealer and buy one for an old mustang, has anyone had luck at the Chevy dealer for one of these for our vans?
Sparky, The truck and car shop in Orange ,Cal. has the 1 3/8 filler hose to fit our vans. Just Google them.
I was there last year and they didn't have any,,,,,,,,,part # is 63-107094 for a $13 foot,,,,,,69-107095 for a $50 four foot piece,,,,,www.truckandcarshop.com
There should be a grommet between the tank filler assembly and the sheet metal where it's screwed in three times. I had mine out, more or less, intact to cut a new one then forgot to replace anyway. I could send you a faxed outline of the old grommet if you wish. Might be better to e-mail me at: ChevyVanMan1@gmail.com as I don't check this site as often as I should. I would think any plastic (like oil bottle plastic) would work just fine. Would avoid the original paper one as it will bring rust if it hasn't already. Please advise, thanks, Mark
