    Cracks In The Frame, Common?
    BloodyKnuckles
    BloodyKnuckles
    Number of posts : 43
    Registration date : 2010-03-14
    Cracks In The Frame, Common? Empty Cracks In The Frame, Common?
    Post by BloodyKnuckles Tue Oct 19, 2010 4:24 pm
    Well, I came across a crack on the drivers frame rail where the motor mount is attached. Being real familiar with uni-bodys I quickly repaired the area.
    My question is, is this a common problem with the Econolines and is there anywhere else I should keep an eye out for additional cracks?
    Thanks,
    BloodyKnuckles
    Number of posts : 2198
    Cracks In The Frame, Common? Empty Re: Cracks In The Frame, Common?
    Post by EconoUSAparts Tue Oct 19, 2010 7:10 pm
    Cracks around the steering box mount were common on 61 and 62 models so I ve been told. Also the spring mounts. My V8 ripped out the frame mounts in my 62 but that was due to a poor install by previous owner. What year vehicle and motor do you have?
    Old Skool
    Number of posts : 1306
    Cracks In The Frame, Common? Empty RE: CRACKED FRAMES
    Post by Old Skool Tue Oct 19, 2010 9:35 pm
    I have been told the 61 to 63's actually had a thinner gauge sheet metal used for the frame, and have seen at least a half a dozen over the years cracked in the front area between the spring perches. When a kid,, ha,ha,ha,,,,,, my 63 pulled the entire front right perch out, and had to have it flat bedded back from the desert one time,, not fair, jumping the truck,, LOL... that was "Jacks" fault, not mine,,,,
    vic
    Number of posts : 339
    Post by lectricman Wed Oct 20, 2010 1:09 am
    I had to fix cracks in my 62 on the passenger side behind both wheels???(front by the brake hose bracket, and rear straight behind the wheel) Don't know why they were there but the truck has led a hard life till now.... Time for her to be babied......
    BloodyKnuckles
    BloodyKnuckles
    Post by BloodyKnuckles Wed Oct 20, 2010 7:30 pm
    The van is a '61 with, I believe, a 170. It's orange but not sure if it's original.
    Thanks for the responses. I will go over the frame periodically and inspect for cracks. That's the only one I found so far.
    Thanks again,
    BloodyKnuckles
      Current date/time is Fri Apr 26, 2024 10:26 pm
