can anyone give me a mopar part # for a 69 318 oil dipstick tube?? also did the dipstick tube change in the later years.?? dodge is tellimg me they can only search back to 1985. thanks.
Scotts_A100
oil dip sticktube
- Number of posts : 8731
oil dip sticktube
Scotts_A100- Number of posts : 160
Re: oil dip sticktube
Dix,
Are you looking for one, I may have a spare as I pretty sure I pulled the one from my bad original block before scrapping it. I can check if you're interested. Also, I'm pretty sure too that these tubes and dip sticks were all the same on the 318, I didn't check it to the replacement blocks tube but I think it was the same.
Scott...
Scott...
Its allways best to pick up a dipstick and tube as a set they do vary in lengh.
when i purchased my A the dipstick tube was rusted but was intact enough to measure it length, when i attempted to pull it out it fell apart and part went into to pan so i had to pull and clean needless to say i went down to auto parts store and bought a chrome generic one measured and cut tube and dipstick.
MY OLD STOCK ONE WAS JUNK I INSTALLED A CHROME ONE OVER THE WINTER IT DID NOT FIT WELL BUT IN BROKE OUT AT NORWALK LAST WEEK. I DO HAVE THE MEASUREMENTS . IDID NOT TRY TO GET THE BOTTOM TAIL OUT YET BUT I THINK I'LL END UP DROPING THE PAN TO GET IT OUT. OFCORES I DON'T HAVE A LIFT SO I'LL BE LAYING UNDER IT AGAIN...
Dix,
I'm attaching a picture of the spare 318 tube and stick that I have. It was never rusted, I had already cleaned it, primed it and put a coat of paint on it.
Also, I noticed that when I uploaded the photo a bit was chopped off on the right side, if you click on the image it will display the full size.
If you have any additional questions please let me know. Scott...
Dip stick tube
Im glad this topic popped up. When my engine came back from the rebuild shop there was a short piece of pipe with a copper tube stuck in one end in the nuts and bolts box. It appears this was a home made dipstick tube that the po had used. Now i Also need to find out the correct length of dip stick and tube for the 67 318. Thanks in advance!!
BADBADGER IS YOUR OIL PAN INSTALLED? OR NOT. IF SO AND YOU HAVE A DIPSTICK THEN SLIDE IT DOWN THE HOLE WERE THE TUBE WOULD BE TILL IT HITS THE PAN AND SUBTRACT 1/4 TO 1/2 INCH YOU CAN DO THIS WITH THE DIPSTICK TUBE IN AS WELL. IF THE DIPSTICK IS TO SHORT YOU CAN CUT THE TUBE WITH A SMALL HAND HELD PIPE CUTTER. I WOULD MEASURE IT A FEW TIMES TO MAKE SURE THE DIPSTICK DOES NOT HIT THE PAN AND TURN ON YOU... THE CHROME ONES ON E-BAY DID NOT FIT WELL ON MINE IT WAS TO TIGHT GOING IN I GUESS THAT IS WHEN I CRACKED IT
I used this one from ebay, I had to grid the chrome off the bottom flange that goes in the block to get it to fit correctly.
http://cgi.ebay.com/ebaymotors/CHROME-SMALL-BLOCK-MOPAR-ENGINE-OIL-DIPSTICK-318-340-_W0QQcmdZViewItemQQhashZitem35aca7894bQQitemZ230529927499QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Dix,
I'm assuming that you received the dip stick and tub that I had sent. I'd not seen or heard anything from you in a couple days. Scott...
sorry my computer crashed i just got it back yesi did receive the tube and i will send you your money out. thanks again scott..
Dix,
Getting the money for the Tube/Stick was not a concern. I just wanted to confirm/know that you received it and that you were happy with it. Have you tried to install it as yet? Scott...
no i was @ norwalk/ chrysler classics when i broke it. when i came home i had to put it away cuz i picked up a escape from flordia for my son in college . had to do brakes and state inspection and get him back on the road . now that is done i can get back to the a-100 i hope i can get the bottom of the tube out with out droping the pan. it looks like mon.eve i will be on that . looks like the alt. will be comming back out just to make room...if it were easy my wife would be doing it.!. as for the dipstick & tube i am very pleased , i could not be happier. thank-you...with the alt. out i may be changing over to the 2 field alt.
