I took my van up to a local shop this week to have the rear gear chunk swapped out since I don't have the garage space for that kind of job. I got a chunk off craigslist, guy said it came out of his running 'Cuda, no problems with it at all. He went to a taller gear for his big block, I'm going to a shorter gear for highway driving. The chunk was a '69 741 / 2.73, mine is a '65 741 / 3.55, he kept the yoke off his chunk but the pinion has the same splines so no biggy.
I give the shop guys the run down, reverse thread lug nuts, etc. and ask them to make sure they swap my yoke onto the new chunk and check it out before they tear the rear end down to do the job (so if it's bad I won't get hit with all the parts/labor and end up with my chunk still in). I specifically asked the old guy to baby sit the job if they were going to let the younger guys work on it.
I just got off the phone with them, they tore the thing all the way down, swapped the chunks and put it all back together before they swapped the yoke and checked it. The chunk wont turn with the yoke installed ... I don't know if its the crush sleeve / pinion bearings or what (the ring/pinion looked great and very clean), they are going to tear it back down tomorrow to take the chunk apart and see whats wrong with it and fix if possible.
I'm sure I'll get to argue over the added labor cost and that really really chaps my behind. To add insult to injury they called me mid week and we added new wheel bearings and seals to the fix because they were shot as well. My $175 job is up to $400 or so and counting. This is why I hate having other people work on my stuff...
