Just wondering if anyone has used one??? And does it help with cooling
+4
kookykrispy
8 posters
High Flow water pumps???
Re: High Flow water pumps???
I dont know about water pumps, but Im thinking of trying a smaller pulley on mine to see if I can help it some, it sounded like smiley gained some on his by going this route, but he may be running a real fan also ?
A good water pump that doesn't just agitate the water should be enough. The thermostat and the passages inside the block/head will restrict flow no matter how much pump is in front of it.
Pay attention to the manufacturer. There are a lot of junk parts with guesswork engineering being sold now.
I'm running a high flow water pump on my inline six. I got it from summit. I think its a flow-kooler brand or something like that. Claims to flow like 30 or 40% more water? The impeller design looked alot better and different than the stocker, so I figured it was worth it. I installed it at the same time I had the radiator re-cored. Also went to a 6 blade fan and a new 160 degree thermostat. The result of all this was a lighter wallet by about $500, but no more overheating in my '64.
I am happy with the high-flow pump.
Kookykrispy - Does your 6-blade fan pull enough air into the doghouse to force the heat out from the top rear? I've been looking at 6-blade and 7-blade fans from Summit Racing. Can't decide if spending extra for the 7-blade is worth it. I'd like to have a lot of air coming in to force the heat out of the rear if that is ever possible. We've had a hot summer here in Ohio and my van is running warmer than I would like it to. I used to own a '64 Chevy (same color) that looked exactly like your picture posted by your name.
richie61- Number of posts : 445
I'm running a 16" universal plastic fan from summit racing. I think it cost me about $18. Its pretty much a cheap POS. If I were to re-do it I think I'd step up to a quality electric fan with a shroud, but that's more $$
I switched from a 7" single groove water pump pulley to a double groove 5.5" and haven't noticed the van running any cooler. I also installed a new 6-blade 17" fan which replaced the original 4 blade steel one. It still runs at 195-200 in traffic and then goes to 220 after shutting it off. I have the belly pan on. My engine is a 355 with a turbo 350. I have considered taking out the original fan shroud and moving the radiator back so the fan is closer to the radiator. There is room to do this and still attach the belly pan to the radiator bottom support. My van is a 1969 108 panel with 3:36 gears. I have a 160 degree thermostat. Would moving the radiator up close to the fan blade lower my temperature? I'd like it to run at 180-190.
From experience= I had a sheet metal shop/friend bend up & weld a metal fan shroud for my 55 chev PU. Ran a straight 4 blade fan-no slip type & I never see any high temps. I also added a elect fan to the front just in case & have never used it. The g10 im building has a shroud ( factory67') and clutch will be used also. I dont forsee ant problems. Im curious if the addition of an electric fan mounted belot the lower louvered panel could help when ststionary?? Seems like even when stopped there would be enough air movement from the fan/shroud would create a high pressure inside the doghouse to keep the heat/air flowing out>> ?? Esp. when moving down the road -now having a low pressure area below the van?? Thoughts from the group??,matt
VCVCSmiley- Number of posts : 73
Going from a 7-1/8" water pump pulley to a 5-3/4" pulley with the existing 7-1/8" crank pulley brought my summer highway temp down from 210˚ average to 195˚ average. No other changes were made. it brought my water pump to crank ratio from 1:1 to 1:24. That's almost 25% more air and water.
I know there are are many other options to help control temp, but a different pulley that can be found for as little as free is a great place to start.
DanTheVanMan- Commissioner
- Number of posts : 7900
Welcome Smiley!!!! Glad you came over.....
