+4
8 posters
Welders warning ....... Brake Cleaner = Phosgene Article
Vanish- Admin
- Number of posts : 5155
,,,Vanish,,,
MCMLXV
wow... that's scary!
m1dadio- Chevy Guru
- Number of posts : 1778
Thats a good artical, In the 50's mechanics used to use burning propane to look for freon leaks in AC systems. The freon burning with the propane would make a green flame to show the leak. That too produced a variation of Phosgene gas. Even though it was known to produce a poisonous gas it was "the way" to check for leaks untill enough guys died from it.
A good dose of phosgene gas will produce an unsurvivable cardiak arrest within 2 seconds acording to the volentier fire fighter training mannual.
M1D
M1D
- Number of posts : 8729
thanks i did not know that
Me either.From the way it reads,sounds like express lane in the check out line.
Brake clean is (was)one of my favorites,leaves no film.
DanTheVanMan- Commissioner
- Number of posts : 7900
Very scary!!! I do this all the time!!!!!!
Thanks....
for posting that article. You may have saved a life or two and maybe worse, long term chronic disability.
Thanks man!
Thanks man!
I was at the local repair shop getting an oil change yesturday and saw a can of that sitting on the hoist, told them about it, they had no clue either. The lad who does most of the mechanical work there paid very good attention !
