    TBI Fuel Injection ??
    Number of posts : 387
    TBI Fuel Injection ?? Empty TBI Fuel Injection ??
    Post by whopman Mon Jul 26, 2010 3:25 am
    Tired of the heat soak. Starts fine first time of the day. Once its up to operating temp and shut it down it is a pain to restart. Sound familiar? So I am toying with the idea of using a TBI fuel injection system from Howell Engineering or Affordable fuel injection. Howell uses a stock HEI distributor and Affordable comes with a HEI distributor..
    Does anyone have any experience with either? Will it get rid of the starting problems? I am not looking for improved gas mileage or performance just reliability..
    Thanks for any and all input!
    Number of posts : 946
    TBI Fuel Injection ?? Empty Re: TBI Fuel Injection ??
    Post by BvrWally Mon Jul 26, 2010 4:07 am
    This cured my starting problems:
    http://www.summitracing.com/parts/SUM-829000/
    B.W.
    hywaychild
    hywaychild
    Number of posts : 389
    Registration date : 2008-05-27
    Post by hywaychild Mon Jul 26, 2010 7:13 am
    Mike (rat van ) from 3 trails has already built a system. With tbi and hei for his inline 6 chevy , he might be able to help
    Post by whopman Mon Jul 26, 2010 7:39 am
    BW the starter is not the problem. I replaced the neg and pos cables with 2 gauge cables and replaced all the alternator wires with fresh wiring. The problem is heat soak. gets so hot it evaporates the fuel out of the carb. You have to hold the gas pedal wide open to start then baby the throttle to build the fuel back up in the carb..
    Hyway id there a link to ratvans set up?
    SnarkyPoet
    SnarkyPoet
    Number of posts : 174
    Registration date : 2009-12-22
    Post by SnarkyPoet Mon Jul 26, 2010 8:39 am
    Have you tried adding a carb spacer? I've had this issue on several vehicles. I usually machine a 1/2" spacer out of G10 or G11 phenolic. This acts as an insulator between the intake manifold and the carb, reducing the heat soak issue. You'll have to make sure you have clearance above your air cleaner to fit the spacer below, however. Adding a spacer has the added benefit of increasing your manifold volume as well.
    Post by donivan65 Mon Jul 26, 2010 9:48 am
    So get rid of the heat,,,,,,this $15 fan is one of the best things I ever ever put on mine and my friends vans,,,,,It keeps you from overheating,,,,,it gets rid of the smell of gas evaporating,,,,,it gets rid of heat soak,,,,,,it keeps the doghouse and you cooler,,,,,,I wouldn't leave home without it,,,,,,,
    TBI Fuel Injection ?? Pictur10
      Current date/time is Thu May 02, 2024 4:47 am
